Lg 42pq3000 just clicks
  • cvel
    • May 2015
    • 64
    • United Kingdom
    Hi could somebody kindly offer some advise please I have this lg 42PQ3000 and upto trying to start the tv all it does is click quite rapidly for 30-40 seconds then won't do anything at all the red light on the front flashes until clicking stops. Anyway reading through some of the other posts regarding similar problems I have tested the pins with the board out of the tv (not with it plugged in yet) and the readings are as follows. Top 17v is reading 14.28 second is 12v and reading 6.3 next two are 5v and both reading 5.38 third is 5v and reading 6.08 not sure if any of this helps or I'm doing something wrong. I repair kitchen appliances for a living so do have some electrical knowledge just not a lot with TV's. Thank you for reading and for any help given in advance.
  • Hamie
    • Apr 2014
    • 1383
    Re: Lg 42pq3000 just clicks
    Pictures of the boards?
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Have you unplugged the Ysus and Zsus connectors ? Also pictures please.
      • cvel
        • May 2015
        • 64
        • United Kingdom
        Hi yes unplugged both ysus and zsus will try for pics now to entirely sure how to upload the though
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Ok cheers
          • cvel
            • May 2015
            • 64
            • United Kingdom
            This is the board if it uploads
            • Hamie
              • Apr 2014
              • 1383
              Can you take a picture of the underside of the board?
              • Hamie
                • Apr 2014
                • 1383
                Also there is a legend table printed here.
                Can you upload a clear photo of it.
                • cvel
                  • May 2015
                  • 64
                  • United Kingdom
                  I'm not sure if my camera flash is t
                  In the way
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Common issue on these is a shorted diode, see the image and check that diode it can cause clicking failure.
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Its the diode next to that transformer check it for S/C.
                      • cvel
                        • May 2015
                        • 64
                        • United Kingdom
                        Could you tell me how to check it for short please
                        • Hamie
                          • Apr 2014
                          • 1383
                          Put your meter in diode mode and measure across the diode.
                          You should get OL one direction and a reading other direction when you reverse your leads.
                          If it just beeps and no reading then it may be shorted. But you'd have to remove it from circuit to be positive Incase something is in parallel to the diode making it test short.
                          • cvel
                            • May 2015
                            • 64
                            • United Kingdom
                            Thanks for that Hamie all diodes close to the transformer are reading ok
                            • Hamie
                              • Apr 2014
                              • 1383
                              With a constant clicking one of the first things I'd check if all caps look good is cracked solder joints.
                              Unfortunalty your picture isn't clear enough, check for anything that looks like this:
                              I'd reflow the joints around anything that moves more than most.
                              Coils, transformers, anything attached to a heatsink.
                              • cvel
                                • May 2015
                                • 64
                                • United Kingdom
                                I can't see any bad solder but on checking other diodes I found one that won't give a steady reading then goes to ol then reads again swaps wires to other side doesn't give a reading at all is this something to check please
                                • cvel
                                  • May 2015
                                  • 64
                                  • United Kingdom
                                  Holding my meter on it it starts to read then ol then starts to read back to ol none of the others are doing this
                                  • cvel
                                    • May 2015
                                    • 64
                                    • United Kingdom
                                    Also found one diode that reads both ways
                                    • Hamie
                                      • Apr 2014
                                      • 1383
                                      It is probably in parallel with something else.
                                      As i said previously, remove one leg of diode and test it again.
                                      If it still tests like it's leaking then it's faulty.
                                      • Hamie
                                        • Apr 2014
                                        • 1383
                                        Anyway I think you're wasting your time randomly checking parts.
                                        Upload a picture of your legend table and check some voltages.
                                        • bk304
                                          Trouble reading BIOS on Dell Precision 3571
                                          by bk304
                                          I am trying to read the BIOS chip installed in a Dell Precision 3571 so I can remove the administrator password. Processor is a 12th gen i7. The service tag ID is 7QV7VL3 (8FC8).
                                          So far, I have not been able to read the chip. I have done this a few times on older 8FC8 BIOS chips and have not had a problem. The BIOS chip is an XMC XM25QH256CXIQ (U2502 marked on the board). I am using a T48 (TL866-3G) programmer and a pogo pin probe for the WSON8 chip. The programmer auto ID is identifying the chip correctly but the ID check comes up FF FF FF. It should be 20 40 19. Pin detect is OK....
                                          Yesterday, 11:51 AM
                                        • SuperAman
                                          PS5 HDMI port diode reading?
                                          by SuperAman
                                          I did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
                                          02-03-2024, 10:16 PM
                                        • GRANDGG
                                          LG 42lw4500 flashing red light , wight light , 2 clicks
                                          by GRANDGG
                                          Hi i have an issue with LG 42lw4500 wich after pressing the power button flashes red then goes solid white light 2 clicks and nothing , the weird thing is SOMETIMES if i leave the tv plugged in it would come on and fuction normally (i should mention that vertical rectangle going from the bottom to the top of the screen have some red dot artafacts it only appear in somthing like the tv input menu and any input i give like vga , but not in the system menu , i thought i should mention this , i cannot confirme if the tv had this issue when it was up and running in its previous owner . ) when checking...
                                          05-09-2025, 12:27 PM
                                        • Fuzzy Fix
                                          0.00 ESR reading on a capacitor
                                          by Fuzzy Fix
                                          Howdy all I have a 90uF Capacitor 200/275 VRMS and measured the ESR . Reading says 00.3 Ohms and about 1/2 a second later 00,0 and says low ESR (Really No Kidding).
                                          I have checked it on the multimeter and reading is 94.7uF well within soec as ir has a 25% tolerance on it.
                                          Can anyone advise me is this capacitor likely to fail in the near future or still good to use.
                                          07-26-2024, 12:05 AM
                                        • redbaron1007
                                          Yamaha HTR-3065 No power/No Standby
                                          by redbaron1007
                                          I got a Yamaha HTR-3065 on the bench currently that's got a no power/ no standby issue.When I plug it in it draws 0.01A from the wall, the relay for the ac transformer never clicks, there are no standby lights on the front, and pressing the power button does nothing. The fuse was not blown but upon measuring the voltages on the power low voltage power supply board (labeled operation 3 pg 89 in the schematic) they do not match what the schematic says they should be.
                                          S9 13.7V
                                          Pwr Ry 0V
                                          AC Det 9.1V
                                          Mgnd 0V GND
                                          The two pins on the transformer for the operation...
                                          09-12-2024, 03:04 PM
