Hisense 32K20DW power problem
  • mcross
    • Sep 2011
    • 201
    Hisense 32K20DW came in for repair. It has normal steady power to main , but the led line to the backlight leds is going from 80.6- to 87 volts, with or without the led line connected, ideas?
    Mike
    Re: Hisense 32K20DW power problem
    Can I get focused pictures of the power supply board, i canot read the pin labels of the black connector that is connected to the main board, I cannot also read the board model number on the bar code sticker.
    What is the Voltage rating of that blue cap close to the LED connector?
    • mcross
      • Sep 2011
      • 201
      The Blue cap is a 100v 100uf , peak meter reads 98.9uf and 0.12 ohm
      heres better pics
      mike
        Then the 80V output at the LED connector is the correct output Voltage, so more likely you have open connection somewhere in the LED string (the LEDs are connected in series).
        Pictures provided by SHOPJIMMY.
        • freakaftr8
          • Oct 2012
          • 3743
          I've seen these sets and thier 42 inch counterparts have a positive wire short to ground inside where the wires attach to the string. It's a piss poor design where the strips have a sharp edge that cuts into the positive wire overtime from thermal cooling and heating up moving the wire
          • mcross
            • Sep 2011
            • 201
            Great help guys, will let you know what i find
            Mike
            • mcross
              • Sep 2011
              • 201
              led was bad in the 2nd string , had a good strip from same model , works fine. Thanks guys for the help
              mike
              • theone111
                by theone111
                3. Problem: TV shuts down
                07-22-2024, 10:36 AM
              • Duranitron
                Asus x512dk rev 2.1 power on problem
                by Duranitron
                When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                11-26-2024, 10:22 PM
              • EazyBone
                LG OLED55C9PUA power problem
                by EazyBone
                Hello, trying to fix C9 55 inch. I have pulled the back and all looks completely normal with nothing burnt so far. This is first time attempting to fix a tv so any help is appreciated.
                Problem. I hit power button, red light on TV turns off and tries to turn on, no picture shows up and then shuts off. This occurred after house power turned on and off, not from a storm.
                I have tested the power going from power supply to main board, all 12v and 20 volt readings are proper when I hit power button.
                The power supply to t con is different story.
                This...
                06-23-2023, 07:43 AM
              • Dr.d
                Help please..Lenovo ideapad 5 14itl05 power and charging problem
                by Dr.d
                I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                04-05-2024, 11:48 AM
                by sam_sam_sam
                03-31-2024, 02:12 PM
