LG 42LC46-ZC picture off sound ok
  • Jimbo555
    • Sep 2015
    • 23
    Now I am by no means a technician. Computers I'm ok with. Trying to help a friend.
    I have changed all the bad capacitors on the PSU board (7 in all). Checked and checked the soldering and it all looks fine.
    The said TV works ok for twelve minutes from cold, then picture goes off and sound remains. It switches on or off fine. I have replaced the P S Board (reputable second hand spares company) and the problem is still there. I have also changed the T-Con board. I have read most of the other forum posts relating to this problem but haven't found anything else I can try or a solution. Any help/suggestions would be appreciated.
    Thanks Jimbo
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LG 42LC46-ZC picture off sound ok
    Does the backlight go out ?
    • Jimbo555
      • Sep 2015
      • 23
      Yes
      • Jimbo555
        • Sep 2015
        • 23
        If I turn it off after the picture goes and back on after two or three minutes it is perfect again for a couple of minutes.
        • vinceroger69
          • Mar 2012
          • 6714
          can you post good clear pictures of all the boards used in your tv, also on the psu can you take all the voltage readings whilst the set is working and when the set turns it self off also post the readings for us to see which if any voltages are bad etc
          ie connector 1 pson 5v tv on 5.3v tv off 5.3v
          • Jimbo555
            • Sep 2015
            • 23
            Will post more pics on Mon afternoon but here's the PSU board. As for volt readings I've a little more to learn yet. Thanks for everyone's help
            • Jimbo555
              • Sep 2015
              • 23
              Sorry been working a few days. Back to the tv now. On further investigation the back light stays on when the picture goes and sound is ok. Hope the pics are ok and someone can point me to where to check the voltages. Last pic is the connector from the PSU to the main board. Thanks for any help
              • Jimbo555
                • Sep 2015
                • 23
                Got some voltage readings. Attached pdf file. Thanks hope someone helps.
                • Jimbo555
                  • Sep 2015
                  • 23
                  Voltage readings from two connectors from PSU boardm to Main board.
                  10 pin connector PSU to main board Voltage readings.
                  Picture fine Picture off/sound ok Backlight still on
                  GND
                  12V 12.12 and 12.09
                  GND
                  3.4V 3.42 and 3.41
                  GND
                  6.5V 6.34 and 6.34
                  19V 19.24 and 19.24
                  13 pin connector PSU to main board Voltage readings.
                  Picture fine Picture off/sound ok. Backlight still on
                  3.4V 3.43 and 3.43
                  ON
                  GND
                  6.5V 6.34 and 6.34
                  A-DIM
                  GND
                  ST5V 4.84V and 4.84
                  BURST
                  -DIM
                  ERR
                  INY
                  CTR
                  GND
                  ST5V 4.84 and 4.84
                  ON/OFF
                  ACD
                  • Jimbo555
                    • Sep 2015
                    • 23
                    Anyone any ideas with these readings. Thanks
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      on the 13 pin connector some of the other pins should have voltage on them too have you tested these?
                      • Jimbo555
                        • Sep 2015
                        • 23
                        No but I will tomorrow.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          if you can please in the working and non working state.
                          • Jimbo555
                            • Sep 2015
                            • 23
                            3.4V 3.43 3.43
                            ON
                            GND
                            6.5V 6.34 6.34
                            A-DIM 3.4 3.25
                            GND
                            ST5V 4.84 4.84
                            BURST
                            -DIM 3.27 3.28
                            ERR
                            INY 4.69 4.69
                            CTR 3.01 3.00
                            GND
                            ST5V 4.84 4.84
                            ON/OFF 2.74 2.75
                            ACD 4.92 4.93
                            • Jimbo555
                              • Sep 2015
                              • 23
                              More readings:
                              Picture fine - Picture off/sound ok. Backlight still on
                              3.4V 3.43 - 3.43
                              ON
                              GND
                              6.5V 6.34 - 6.34
                              A-DIM 3.4 - 3.25
                              GND
                              ST5V 4.84 - 4.84
                              BURST
                              -DIM 3.27 - 3.28
                              ERR
                              INY 4.69 - 4.69
                              CTR 3.01 - 3.00
                              GND
                              ST5V 4.84 - 4.84
                              ON/OFF 2.74 - 2.75
                              ACD 4.92 - 4.93
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                on the tcon board there will be a fuse can you check the voltage to each side of the fuse when the tv is working and when the tv is not.
                                • Jimbo555
                                  • Sep 2015
                                  • 23
                                  Sorry Vinceroger can't see a fuse on the T-Con board. See pic in post 12.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    there is a fuse says f1 with a tk printed on it above printing that says vin 12 volts by the lvds lead be carefull not to slip and short anything out we just want to see if the voltage goes when the picture goes off check both sides of fuse too just in case.
                                    • Jimbo555
                                      • Sep 2015
                                      • 23
                                      Great I see that but where do I put the negative.
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        on tv metal chassis will do you should see 12 volts i wonder if thats dropping when the tv goes off
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
