Sharp aquos LC-40LE810E
  • Nightmare0
    replied
    Re: Sharp aquos LC-40LE810E
    (PD-1-2)UR13.2V(SIGNAL): 13.01V
    (PD-3-4)S13V.2(AUDIO): 13.01V
    (PD-5-6)SGND(AUDIO): 0V
    (PD-7-8)SGND(SIGNAL): 0V
    (PD-9)AC-DET: 0V
    (PD-10)PS-ON: 3V
    (PD-11)BU5V: 4.99V
    (PD-12)PNL-POW: 0V
    I am getting these voltages only when I plug tv to power. Because after while, tv will show error code and only 5v is present. Should I try that resistor on top of that second resistor?
  • rievax_60
    replied
    Originally posted by Nightmare0
    (PD-1-2)UR13.2V(SIGNAL): 12.9V
    (PD-3-4)S13V.2(AUDIO): 12.9V (its not misspelled, its written like this)
    (PD-9)AC-DET: 0V
    (PD-10)PS-ON: 3V
    (PD-11)BU5V: 4.9V
    (PD-12)PNL-POW: 0V
    What are these voltages now? Keep in mind that some of these voltages might not stay up for long after the mains is applied.
    I think AC-DET can only be high when PS-ON is high. It has been a few months since I worked on s similar model here.
  • Nightmare0
    replied
    Here are photos after I put all original optos back. You can check, they are in same position. I added photo from shopjimmy so you can check they are really in proper way. Also photo of that red led. Red led is not still on. It is flashing like: maybe 20 seconds on, off for few seconds afaing 20 seconds..... after few flashes, led will turn off and nothing else happens.
    I was not using TV with this fix. I tried that once, when I first tried for maybe 30 seconds until I took photo.
    After opto change, it started to act like that. So how bad is it? All pins have same voltage. If you need more info just let me know.
  • Nightmare0
    replied
    Here are photos, after I changed all optos. I noticed they are not same brand. 2 of them were sharp and 2 of them different. Also I checked if I am fitting them in correct way. There is sign 1 on motherboard for dot in left top corner. Also there are marks on side and motherboard like half circle. So I am sure I fitted them correctly.
  • fzabkar
    replied
    "I took out pin 9 - AC-DET an just plugged it next to pin 11 - 5v. Without any soldering. It's just touching and TV has started up. Everything seems to be working."
    The AC-DET signal is normally tied to the supply via a pullup resistor. By connecting pin 9 directly to the BU5V supply pin, you would have impressed the supply voltage directly onto an MCU GPIO pin. This is not always a safe thing to do.
    Edit: IC2002 is powered from BU+3.3V, so impressing BU5V onto its AC_DET pin would have resulted in latchup without any current limiting. I could be wrong, though.
  • rievax_60
    replied
    The first thing to check is that the optos are fitted the correct way. They dont all face the same way. Take a clear photo of the top before you do anything else.
  • Nightmare0
    replied
    I was celebrating too soon.
    I changed all optos. Measured all pins...getting same voltage on all pins like before. Tried that magic trick with resistor again, but this time tv didn't turned on. Not even led. Just red led on mainboard.
    I put all original optos back. Same... Red led on mainboard. When start without that resistor trick, tv is still flashing with same error.code. getting same voltages. Just resistor trick doesn't work anymore.
    Could I burn optos? Or I really screwed something? I will send you photos tomorrow, I am sad and tired, so I am going to sleep now. But there weren't any cold joints, bridges, used flux, everything seemed nice.
  • rievax_60
    replied
    The function of the AC-DET is also to warn the controller of imminent loss of supply rails so that it wont risk writing to memory resulting in corruption.
    replied
    Glad to hear, so now we know that it is the AC-DET failure only, so it is either the resistor for the circuit is marginal or changed in value (goes higher resistance), or bad opto per suggestion by other members.
    The purpose of the AC-DET is not to allow the TV to come on if the AC Voltage feeding the TV is too low, so right now it is the protection circuit is causing the fault due to its own failure.
  • rievax_60
    replied
    If you do not restore proper function of the AC-DET, you will risk EEPROM corruption. Your TV will have similar function to that of a brick.
  • Nightmare0
    replied
    Wow. You guys are awesome ! Real professionals.
    I will test it tomorrow. If you want, I can make some measurements for you. Is there anything that I should check before soldering it? I will also keep that 68k resistor and optos for future.
    /edit
    I added quick photos I will post more, when You allow me to solder that.
  • Nightmare0
    replied
    Ok. I have bought resistors. 560 ohm for AC-DET fix.
    Also bought 68k smd resistor and also 33k and 4 opto-couplers.
    First I will fix that AC-DET and will post results.
    Also I got crazy idea. If everything fails, is it possible to buy some lvds to hdmi converter and use this tv only for set-top box? I don't want to do that now. Just if it is possible
    replied
    I do not know what the main board will do when it detects AD-DET problem, I would it should take away the PS-ON signal and then blink and error code, but in this one the PS-ON is still present, it may be true that it will shut down the panel Voltage, that is why he need to fool the main board that AC-DET is OK by pulling the line high and see what will happen next which is what I am waiting to see the result when he gets the resistor.
    I believe PNL-PWR is the command pin form the main board, there should be another connector on the power supply board with '12V_PNL' that goes to the T-CON board.
  • fzabkar
    replied
    Originally posted by budm
    So so far you do have power supply board problem due to AC-DET circuitt, and then then PNL-PWR problem.
    Couldn't the main board be switching off PNL-PWR in response to the AC-DET failure?
  • rievax_60
    replied
    That's right, the 68k is soldered on top of the the existing 82k or replace it totally with a 33k. Its best to search for the PC817 opto to find what's best available in your area.
    Or just play it safe and do nothing else if the resistor mod works.
  • Nightmare0
    replied
    not yet. I will read whole thread soon.
    you mean that 68k resistor fix? I can try that. Also can you help me to find replacement for optocouplers? In that thread someone use PC817. Can I try them too?
  • rievax_60
    replied
    What are optos, are they easy to get and replace? How much they cost? won't be easier to buy whole power supply?
    The full name of the part is "opto-coupler". Did you look at the other thread? it explains more including a temporary fix. All if your TV has the same problem.
    https://www.badcaps.net/forum/showth...AC-DET&page=14
  • Nightmare0
    replied
  • rievax_60
    replied
    If it is the AC-DET problem, I recommend that all 4 optos be replaced. Read the other thread.
    replied
    Anything between 330~1K will be fine.
    "And what about that PNL-POWER?" That is another problem.
  • scubacamper
    Sharp Aquos LC-70C6400U Half Screen Dark
    by scubacamper
    I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
    Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
    when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
    05-03-2025, 12:19 PM
  • sefoster
    Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
    by sefoster
    I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
    11-20-2022, 09:29 AM
  • foxyUK
    Sharp Aquos LC-32LE600E, No 12v as no PNL_POW
    by foxyUK
    Can anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
    The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
    There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12....
    10-22-2024, 10:27 AM
  • thesharpfella
    Is this white-washed screen caused by a faulty T-Con board or panel? Sharp Aquos c70le735x
    by thesharpfella
    Hello esteemed gentlemen. I have owned this LCD TV since 2012. The only repair was the replacement of the PSU a few years ago. Apart from that, no issues. Recently, all was working fine until I switched on to see it appear as so. The day before it was working fine. There is sound. Could this be a T-Con board issue? If not, what could it be? Thank you.
    07-23-2024, 10:37 AM
  • olegeisler
    SHARP AQUOS LC-70LE836S only blinking - freebie
    by olegeisler
    Got this SHARP AQUOS LC-70LE836S for free - did some basic troubleshooting, and found manual - without detail schematics though. Comes from a meeting room with extremely few working hours.
    Symptoms :
    When connected to mains, the logo blinks continously, approx 6 times per 10 seconds.
    A press on MENU as per the manual changes this to one short blink, one long and then repeats.
    Only 5V ( Standby ) on PSU module present, no AC_DETECT, no 12V, no 13V, no PS_ON from mainboard.
    As I see it mainboard has some kind of life, but does not...
    07-23-2022, 07:01 AM
