Sharp aquos LC-40LE810E
  • rievax_60
    replied
    Re: Sharp aquos LC-40LE810E
    Those voltage readings show that the AC-DET is working properly.
    There must be something else wrong, Does the voltage on pin 1 disappear after 7 seconds also?
  • Jstone86
    replied
    I also measured the pf Voltage of PC7703 with these reults which immediately drops to zero like after 7 secs or so
    PIN 3= 4.74v
    PIN 4= 4.90V
  • Jstone86
    replied
    mr rievax 60,
    this is the volts i get after i replace R7019 with a 33K cabon film resistor.
    PIN 1 - 12.9V UR13.2V (SIGNAL)
    PIN 2 - 12,9V UR13.2V (SIGNAL)
    PIN 3 - 12,9V S13.2V (AUDIO)
    PIN 4 - 12,9V S13.2V (AUDIO)
    PIN 5 - 12.9V SGND (AUDIO)
    PIN 6 - 0V SGND (AUDIO)
    PIN 7 - 0V SGND (SIGNAL)
    PIN 8 - 0V SGND (SIGNAL)
    PIN 9 - 3.10V AC-DET:
    PIN 10 - 3.03V PS-ON
    PIN 11 - 4,9V BU5V
    PIN 12 - 3.25v PNL-POW
  • Jstone86
    replied
    OK bro I will try it and let u know tomorrow cuz it's late here
  • rievax_60
    replied
    Measure some pin voltages on the PD connector as the TV is being turned on.
    Look at post 21 as an example.
    I mainly want to know what happens at pins 1 and 9.
  • Jstone86
    replied
    I replaced r7019 with 33k carbon film resistor and it didn't work basically same 2-2 LED blink light. I Mayb I should wait and order smd 33k resistor from aliexpress
  • Jstone86
    replied
    I couldn't get 68k or 33k SMD resistor to buy from my local electronics shop so I bought 68k and 33k carbon film resistor so I hope it will work. The two pins of carbon film resistor is it interchangeable or reversal so that I can solder on top of r7019 on any of the two pin?
  • Jstone86
    replied
    Thanks I will try and give you feedback
  • rievax_60
    replied
    Yes, solder a 68K on top of R7019 or replace R7019 with a 33K or something a bit lower. The value is not critical. This mod increases LED current to compensate for the loss of the opto's CTR due to aging.
    I don't recommend jumpering pins 9 and 11.
  • Jstone86
    replied
    I have same model with same flash beep 2-2 error problem.after going through all the comments on this thread can someone please confirm if all i have to do to solve this problem is to just solder 68K resistor on top of R7019??should i forgone plugging resistor next to pin 11 and other end of resistor to pin 9???
  • meme123
    replied
    I changed the resistor to 570 ohms and also resist 68k as you said in the race I had the same TV and holidays and you as you said and succeeded television, but this television did not respond help
  • meme123
    replied
    Hi, I'm a Sharp Acua lc 810 with a fault similar to the holidays but the flash is frequent and does not stop please help outside flute 5 v only
    replied
    Normal condition AC-DET = H (HIGH) = >2.5V, typical for this board is around 3~3.5VDC range, L (LO) = <1V for fault condition.
    AC-DET signal tells the main board if the incoming AC is within the operating range of the power supply or not.
  • sathishbds
    replied
    Is there the pins (9/AC_DET) of P9601 at “H”?
    what is mean by "H" here?? Can i anyone tell me. Thanks in advance.
  • angel-boy
    replied
    I fix the tv , teste first time with pin 9 , plugged in pin 11, and replace R7019 with 34k resistor , and finish , tv works great
  • rievax_60
    replied
    The previous posts don't say exactly that. The safest and most direct action is to add a 68K on top of R7019. It is next to Q7802. Look at post 79.
  • angel-boy
    replied
    hy , i have the same problem
    and I took out pin 9 - AC-DET an just plugged it next to pin 11 - 5v , the tv power on now,
    so the next step will be to change 68k smd resistor and also 33k and 4 opto-couplers ?
  • Nightmare0
    replied
    I just wanted to donate straight to you. Anyways I will donate at least to this site. Thank you
  • rievax_60
    replied
    I suspect that most members are happy enough to help, so long as it doesn't become too frustrating.
    If you want to donate, it should be to this forum which enables members to help each other.
  • Nightmare0
    replied
    I know. I was asking, if you both will get something of that :-)
