Re: Sharp aquos LC-40LE810E
There is a yellow Donate button at the very bottom of this page.
Ok then. And what about that donate?Leave a comment:
The flickering problem was caused by the opto further up on the board, the one on its own. Dont worry about it. It may never fault.Last edited by rievax_60; 10-13-2015, 11:55 PM.Leave a comment:
That is for tonight folk, on to the next project, cheers.Leave a comment:
Actually it was the lower back light setting that showed up the flickering problem on the Sharp TV that I fixed.Leave a comment:
But that user fixed it by replacing all optos, didn't he? I am going to keep this tv in my bedroom. I am not.going to profit on this tv with questionable life span.Leave a comment:
You should also turn down the Backlights level down as low as possible but still have good pictures in the user setup menu, this will help extending the LEDs' life, they will run cooler.Leave a comment:
Keep in mind the back light flickering fault that can develop that is mentioned in the other thread.Leave a comment:
Thank you very much. Now I will put tv together and test it. Sorry for my mistakes. You managed to help me even my lack of electrician knowledge and not perfect English. This experience made me to learn a lot of interesting stuff. I hope this thread can help someone in future. I can see, there is donate button on the bottom. If I donate, will you get something?
Co-worker said, he also has some broken tv in basement. Maybe I will make another thread to help him. But first I will give you some rest :-) it had to be exhausting to work with me. Thank you again and provide me some information, where can I donate.Leave a comment:
That is what I expect, the OPTO should be on when AC is normal so the LED inside the Opto is turned on, as you can see the Vf of the LED is 1.01VDC (per spec of the OPTO, the typical Vf is 1.2V), so when the LED inside the OPTO is on the Photo-transistor is also truned on that is why the Vce (pin 3-Emitter and pin 4-Collector) is low, the transistor is in saturated condition (per spec the typical Vsat is 0.1V, MAX IS 0.2).
So when you add that 68K Ohms resistor the LED will have more forward current (If) so the Photo-transistor is turned on more (it has to do with Current Transfer Function (between 50%~600%) of the Opto).
The reason I ask about the VCC Voltage at those two points is to find out if it is too low, and the OPTO may be operating at marginal point already so it does not take much for it not to be fully on.
The output of the OPTO is used to drive the switched transistor Q7061, IC7061 that control PD-PIN 9 (AC-DET) to make it HI or LO depends on the AC Voltage level.
So you can leave it like that with that added resistor.Last edited by budm; 10-13-2015, 11:12 PM.Leave a comment:
Budm, you are right. It worked only once.
So again sorry for your time while I soldered resistor to.wrong place. That's what you will get when you solder at 6 am.
So now...... Again, one more time .
This time I soldered 68k resistor on right place.... Put everything back. Tv is working. Now it's time for measuring. Tell me what do you want to measure. Is this resistor final fix? Or should I buy something?Leave a comment:
Photos of 68k resistor fix
Also found out, that that red led (D3301) on mainboard is still flashing while tv is on.Last edited by Nightmare0; 10-13-2015, 10:33 PM.Leave a comment:
Any, even we are not getting the correct AC-DET signal regardless, you still should be able to fool the main board using the resistor to pull AC-DET high, you did pull the AC-DET wire off the PD female connector when you use the resistor the second time but the TV will still not start, right?
To me that is a bigger problem if you cannot get it to work as before.Leave a comment:
BTW, PD-9 (AC-DET pin) is not driven directly by the OPTO.Leave a comment:
Omg.... I am tired and retarded..... I really soldered that resistor on top of.wrong resistor. f-ck, sorry for your time.... Going to fix that....Leave a comment:
You want ne to measure voltage between marks + and - vcc1? It will take me some time,.since its back side of pcb and I am putting it back to tv every time. I have to figure out. Just tell me if to measure between these +- pads. I will solder some wires and.measureLeave a comment:
by scubacamperI found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display... -
by sefosterI have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
by foxyUKCan anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12.... -
Hello esteemed gentlemen. I have owned this LCD TV since 2012. The only repair was the replacement of the PSU a few years ago. Apart from that, no issues. Recently, all was working fine until I switched on to see it appear as so. The day before it was working fine. There is sound. Could this be a T-Con board issue? If not, what could it be? Thank you.
by olegeislerGot this SHARP AQUOS LC-70LE836S for free - did some basic troubleshooting, and found manual - without detail schematics though. Comes from a meeting room with extremely few working hours.
Symptoms :
When connected to mains, the logo blinks continously, approx 6 times per 10 seconds.
A press on MENU as per the manual changes this to one short blink, one long and then repeats.
Only 5V ( Standby ) on PSU module present, no AC_DETECT, no 12V, no 13V, no PS_ON from mainboard.
As I see it mainboard has some kind of life, but does not... - Loading...
