Re: Sharp aquos LC-40LE810E
I will explain to you later as to why the VDC measured between pin 3 and pin 4 of the opto goes down when you add 68K resistor on the LED drive side. If you look at my picture on post 70 you will understand why.
I put it on R7019
In that post he is saying R2019 but its typo. If you check photo he really soldered it to R7019
Please check that photo I added in post 63, if I am measuring in correct way.
Leg 3 of PC7703 with 68k resistor soldered on top of existing resistor according my photo to gnd I got 1.68vLeave a comment:
So you now have 2v on pin 3 to ground? same as before? It should have made a large difference.
Where did you put the 68k? Look at post 279, https://www.badcaps.net/forum/showth...AC-DET&page=14Leave a comment:
Leg 3 to gnd is showing 1.68V. Tomorrow i will buy 10 more optos and change all of them againLeave a comment:
I just added 68k resistor. I forgot to take a photo. Now between 3 and 4 opto leg I am getting 3,06V
Tv didn't started. On AC-DET pin 9 I am still not getting any voltage.Leave a comment:
If pin 3 doesnt go over 3 volts after the 68k is added, then replace PC7703. BTW opto couplers dont like being heated for too long.Leave a comment:
Is that after you added the 68K?. You didnt say. At 2.5v on pin 3 of PC7703, you might see some voltage on the AC-DET but the TV will not start unless AC-DET is solid high level, no pulses.Leave a comment:
Sorry I confused you. First time that trick was working I used 570ohm resistor. I just plugged resistor next to pin 11 and other end of resistor to pin 9. I never tried that without resistor. Just after opto change that resistor trick didn't worked again. Same as I put original optos back.
That voltages from pin 3 and 4 I got to GND. Voltage of PC7703 between pin 1 and 2 is 0,99V and between 3 and 4 is 2,56V (this voltage goes to 0,08v after tv starts to show error code)Leave a comment:
"Tried that magic trick with resistor again, but this time tv didn't turned on. Not even led. Just red led on mainboard. " I am a little bit confused here, the first time you did not use any resistor between the AC-DET wire ("I took out pin 9 - AC-DET an just plugged it next to pin 11 - 5v. Without any soldering") and the STBY5V, you had it connected directly without the resistor, and now you are using the 330~1K resistor between the 5V and the AC-DET but the TV will not work this time, is that correct?
BTW, what is the P/N of that opto for the AC-DET?
What DCV do you get between pin 1 and pin 2 (the LED side), and between pin 3 and pin 4 (the photo-transistor side)? Notes: The measurement is for between the legs, not with ref to the circuit GND.Last edited by budm; 10-13-2015, 06:51 PM.Leave a comment:
Yes, solder in the resistor. pin 3 on the opto needs to be well over 2.5v.Leave a comment:
PC7703 legs 3 -2.1V and 4 -4,9V
Should I solder that 68k resistor on top of other now?Leave a comment:
Yes, that is a good idea. I keep thinking about damage on the main board also. I dont understand why there should be damage because he used a series resistor.Last edited by rievax_60; 10-13-2015, 03:03 PM.Leave a comment:
If the "resistor trick" doesn't work anymore, then I can't see how modifying the sensitivity of the optocoupler will change anything. ISTM that there is now a problem on the main board.
I would check whether AC_DET is shorted to ground on the main board.Leave a comment:
You can do a search on the part number or "opto coupler". Measure pins 3 and 4 of PC7703.Leave a comment:
Ok, i will do that as soon I will get from work.
I don't know how these optos work. Which legs should I measure? I will post results of all optos, so you can check that.Leave a comment:
I made a mistake before. PC7703 is the lower one.Leave a comment:
(PD-1-2)UR13.2V(SIGNAL): 13.01V
(PD-3-4)S13V.2(AUDIO): 13.01V
(PD-5-6)SGND(AUDIO): 0V
(PD-7-8)SGND(SIGNAL): 0V
(PD-9)AC-DET: 0V
(PD-10)PS-ON: 3V
(PD-11)BU5V: 4.99V
(PD-12)PNL-POW: 0V
I am getting these voltages only when I plug tv to power. Because after while, tv will show error code and only 5v is present. Should I try that resistor on top of that second resistor?
Although it seems that you have another fault also.Last edited by rievax_60; 10-13-2015, 06:37 AM.Leave a comment:
by scubacamperI found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display... -
by sefosterI have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
by foxyUKCan anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12.... -
Hello esteemed gentlemen. I have owned this LCD TV since 2012. The only repair was the replacement of the PSU a few years ago. Apart from that, no issues. Recently, all was working fine until I switched on to see it appear as so. The day before it was working fine. There is sound. Could this be a T-Con board issue? If not, what could it be? Thank you.
by olegeislerGot this SHARP AQUOS LC-70LE836S for free - did some basic troubleshooting, and found manual - without detail schematics though. Comes from a meeting room with extremely few working hours.
Symptoms :
When connected to mains, the logo blinks continously, approx 6 times per 10 seconds.
A press on MENU as per the manual changes this to one short blink, one long and then repeats.
Only 5V ( Standby ) on PSU module present, no AC_DETECT, no 12V, no 13V, no PS_ON from mainboard.
As I see it mainboard has some kind of life, but does not... - Loading...
