Vizio VL470M BACKLIGHTS BUT NO PICTURE
  • bluedawg
    Bluedawg
    • Mar 2015
    • 60
    • united states
    I was working on this tv because half the screen had went out as in bad connection or bad screen.I could wiggle cable going to screen a bit and get a full pic but one side not clear but then I Stuck a screwdriver in between frame and tiny boards that run along top of tv that has the ribbons that send the picture onto screen and the entire picture both sides went blank and now I have back lights on and no picture of any kind and if I unhook cables from main board to screen it has no effect or even flicker on screen.My question is could I have shorted out something on the main board and or on the tiny long green boards that run along top of frame??? i can purchase a new main board but I wonder if I already had a bad screen and it would not be worth it??? thank you in advance for any help,
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8326
    Re: Vizio VL470M BACKLIGHTS BUT NO PICTURE
    Hmm... now that was a mistake to do... In order to test that main board in the condition the TV is in right now you need to check the LVDS outputs on the main board with an oscilloscope, in order to make sure on what board the problem lies. Could also be that the panel drivers.
    So if you can get your hands on a 100mhz or so oscilloscope go from there. Other than that you may waste some $$$. You could try to only plug in one ribbon cable at the time and see what that does. Also inspect that little board for fuses.
    • bluedawg
      Bluedawg
      • Mar 2015
      • 60
      • united states
      Yes it was a mistake and a lesson learned. U can hook unhook wiggle do whatever with ribbons now and it has no effect on the grey color which is just back lights shining through screen on tv. I also will check those panel drivers for a fuse . Thank you
      • Mgiffune
        by Mgiffune
        06-09-2024, 10:28 AM
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • spice_disc
        Vizio TV M50-C1 reboot cycle and static on screen
        by spice_disc
        I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
        The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
        09-08-2024, 02:37 PM
      • arbitarytwist
        Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
        by arbitarytwist
        Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
        Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
        03-01-2025, 01:16 PM
      • dicky96
        HP Elitebook Screen blank - backlights but no image
        by dicky96
        Hi guys
        I'm trying to fix this laptop screen
        Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
        OK so I have the original screen which works but has lines across the bottom quarter of the screen
        I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
        04-28-2021, 07:30 AM
