slightly washed colors - menu not affected?
  • J.Emerick
    • Oct 2015
    • 4
    • france
    i read all i could on the subject but found nothing exactly like this.
    the tv lcd model is le32b530 - 32".
    This tv is placed as a monitor (vga connection) and hdmi for gaming systems.
    More than a year ago the screen was all green (green yellow tint on the whole screen) when connected via hdmi (for gaming or as a monitor)
    Vga was not affected for many months, then the same happened which was resolved by updating the firmware (dark red was more present)
    Recently it happened again (green yellow tint) that was resolved with the picture options but the screen is slightly more blue (steel grey blue).
    the strange part is that gamma option is not working (adjustement has no effect), backlight is working and the menu colors are bright and distinct.
    Testing colors calibration shows perfect and distinct colors.
    Selecting warm colors in the options result in washed green yellow colors.
    This is visible on the entire screen, cold colors has no tint just slightly more blue greyish brighter colors.
    Thought it might be the t-con but not sure.
    Thank you for any informations!
    John.
  • vinceroger69
    • Mar 2012
    • 6714
    Re: slightly washed colors - menu not affected?
    can you post pictures of the boards in your tv also one good picture of the tcon so we can see what gamma chip its using.
    • J.Emerick
      • Oct 2015
      • 4
      • france
      vincentroger69,
      i have a few small pictures of the boards (i took note of serial numbers, etc...) what i found surprising is the amount of hot glue globs on the connectors (i had read about that).
      i checked the wires, capacitors, fuse, resistors.
      The wires going to the t-con are very thin (connectors encased with hot glue) the cover must be removed to show the board, the speakers should also be removed as the screws are under them (i didn't touch any of that).
      Is it possible to have info on the t-con via the advanced (service menu)?
      • vinceroger69
        • Mar 2012
        • 6714
        ok have you got the numbers from the tcon board we maybe able to find a oline picture
        • J.Emerick
          • Oct 2015
          • 4
          • france
          I got the numbers for the mainboard, inverter, serial etc... but the t-con numbers are under the cover and for that the cable would need to be removed.
          The hot glue is keeping everything in place so i didn't touch any of that (the connectors are glued down with the wires)
          i've read that the t-con affect everything including menu screen, and if the menu is not then the mainboard shoud be looked at. (is it correct?)
          • vinceroger69
            • Mar 2012
            • 6714
            I honestly dont know my self as still learning have you got a picture of the fault? another member may of saw this before.
              LCD LED TV Service Menu Codes
              ALL LCD LED TV SERVICE MENU CODES
              Service Menu Code with Board Name
              China Universal Board / Jumper Board Service Menu Code
              Changhong Ruba Service Menu Code
              Ecostar LED TV Service Menu Code
              Orient LED TV Service Menu Code
              Haier LED TV Service Menu Code
              TCL LED TV Service Menu Code
              Samsung LED TV Service Menu Code
              LG LED TV Service Menu Code
              Videocon LED TV Service Menu Code
              Supra LED TV Service Menu Code
              Toshiba LED TV Service Menu Code
              Symphony LED TV Service Menu Code
              Veste/ LED TV Service Menu Code...
              10-31-2024, 03:58 AM
            • Robby-Gr
              TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
              by Robby-Gr
              I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
              However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
              The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
              Additional issues:...
              09-27-2025, 12:02 AM
            • Retro140
              Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
              by Retro140
              So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
              To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
              06-18-2023, 06:13 PM
            • Ierwin
              Philips 58PUS7805 Menu working but no/weird picture from video sources
              by Ierwin
              I got a 58pus7805 that shows some weird behavior.
              The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
              However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
              I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
              I managed to install the latest official firmware by holding the control button while plugging...
              03-10-2024, 12:50 PM
            • vf fa
              EIZO CX270 - No signal but Backlight and Panel works, logo works, admin menu works. OSD doesn't. What?!
              by vf fa
              Hi, so i guess I´ll have to make a new topic here, as i browsed through hundreds of other threads but couldn't find a solution to my problem yet.
              I got a EIZO CX270 from a friend. He said it doesn't work anymore and wont display any signal or take any OSD inputs. Well, as an aspiring photographer I couldn't say no, could I? Thought it was an easy game, replace a bad cap and have a working monitor. But nooope, it wasn't supposed to be this easy.
              So let me start with the problem description. I'll try my best not to skip anything so this might get rather long.
              01-31-2024, 01:40 PM
