what fails on main boards?
  • mattstolte
    • Dec 2013
    • 612
    • usa
    Couple questions what parts usually fail on main board. Like for example when main board will turn on tv but no backlight what is that? Or when backlight will turn on but no picture.?
    Re: what fails on main boards?
    Could be virtually anything!
    Here's a short list:
    • regulators / power supplies for the lower main board voltages (DC-DC buck converters, LDOs, rarely boost converters)
    • flash memory, particularly large NAND devices and SPI devices
    • EEPROM memory corruption
    • processor soldering failure
    • SMD fuse failure
    • electrolytic capacitor failure
    • shorted MLCC ceramic capacitor or tantalum capacitor
    • saddle_au
      Waste Warrior
      • 121
      You can add cables and connectors to that fine list.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8218
        the odd transitor
          "Could be virtually anything!"
          +10
          • SteveNielsen
            Retired Tech
            • Jun 2012
            • 2327
            +10
            Yes, and in real a case it would actually be something.
            If Schroedinger did have a cat it would most certainly be dead by now.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Anything !
              Voltage regulators
              Bga solder
              Ceramic caps
              Epprom or flash chip
              Ram chip
              Fuse
              • JSin21
                Compatibility of main boards between different variations of samsung MU6100
                by JSin21
                Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                I have Samsung Smart TV UA65MU6100WXXY version DA01
                Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                11-27-2023, 04:54 AM
              • Yanleb
                Compatibility of Samsung Y Main boards LJ92-01732A no rev vs rev AA2
                by Yanleb
                Hi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
                If they are not compatible why did Samsung give them the same part number to begin with?
                08-04-2025, 11:35 PM
              • ugamazing
                Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                by ugamazing
                I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                12-17-2024, 07:05 PM
              • Dani_2024
                by Dani_2024
                10-28-2024, 05:06 PM
              • ygorsan
                by ygorsan
                🧩 Problem Summary:
                • I
                07-28-2025, 08:34 AM
