I have a Samsung PN64F5300AF that has been casting the (not so uncommon) pinkish/green tint on white areas of the image. I recently R&R'd the Ys and Xs boards to test the caps, check the Vs and Va, and Caig cleaned all the connectors, including the scan board ribbon cables.
Before reinstalling the back cover, I ran the TV for an hour, and was happy to see the display problem was gone. So back on went the rear cover, and in less than a minute, the display problem was back.
I checked the inside of the cover, and the back of the TV, to make sure there was nothing out of place.
I have since tested the back-cover theory three times this past month, running the TV a couple days with the cover on, and a couple days with it on, and I get the same results every time. I have now been running the TV for over two weeks without the back cover, and the picture has never looked better. I'm thinking the cover may be causing some kind of electrical resonance, or oscillation.
Has anybody ever experienced this? Is there something I can line the inside of the cover with, that will provide insulation between the circuitry and the metal cover?
Thank you, Rob
Thank you, Rob
