TV Remote control causes volume control to turn to full loudness
  • sirzur
    • Nov 2007
    • 15
    I have an Auriga LCD TV which is a bit unusual.
    Whenever I use the TV Remote to turn up the volume (or turn down the volume), the volume automatically goes to full loudness or turns completely off. I thought it might be the remote transmitting too many signals, but even if I just press the vol+ button quickly and then put my thumb over the infrared diode, it still happens. Also happens to the prog+ and prog-. Anyone has any suggestions of diagnosing (or even remedying this?)
    The volume and prog control on the TV works prefectly ie. it will increment once everytime the button is pressed.
  • zandrax
    Hit and miss
    • Dec 2007
    • 1157
    • Italy
    Re: TV Remote control causes volume control to turn to full loudness
    Most if not all remotes are based on the infamous chiclet keyboard (a rubber keyboard with rubber/iron contacts): these contacts are prone to dirt the remote board and fake signals, so open the remote and clean both keyboard and board contacts with alcohol - isopropyl one is better but etilic one is good enough.
    If cleaning doesn't solve your problem, check for almost-dead batteries or bad capacitors (remotes should have one or two caps).
    Zandrax
    Have an happy life.
    • chipper
      • Aug 2008
      • 95
      I was going to say that "sticky" inner remote control buttons could be the problem , clean and retry. But - what you really need to do is to check the tiny button mounts for looseness as well. Each button sends a signal to the tv , but if it gets interupted and is incomplete , the last send is repeated , especially when you have a loose button connector on the remote board. That would explain why you keep getting "sound" changes on unrelated buttons. The condition can also be the same regarding any loose wire or anything on the small inner PCB board.
      That's why dropping a remote can cause trouble , and eating around the remote is a no no.
      • crackedprint
        Sony HCD-HX80R Amplifier Volume Control Problem
        by crackedprint
        I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
        I have tried a Cold Reset as per the service manual.
        I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
        I have looked all the way through the service manual and tried many online...
        01-21-2025, 12:18 PM
      • piipo
        Old Privileg 5.1 speakers remote control question
        by piipo
        Hi, I have an old Privileg brand 5.1 speakers. I have lost the remote control. I have an universal Harmony remote but there is no Privileg brand in it's software to add. Does anybody have an idea what alternative brand for a remote can I try instead? I'm attaching an image of what the speakers looks like. The image shows 2 main speakers, they are 5 + 1 in total. Thank you very much
        09-18-2024, 01:55 AM
      • hemant_2222
        Schematic for Denon Remote Control RC1156
        by hemant_2222
        Hello Everyone,
        Hope everyone is enjoying their repairs at hand!.
        I am looking forward to get the schematic of Denon remote control RC1156. Actually long time no use of the remote leaked the battery thereby corroding few parts as well as the tracks.
        I was able to join few of them but the remote is still not working, so i am looking forward for your help, in case anyone understand the schematic or the remote circuit diagram and could me assist me in repairing it.
        Please refer to the attached picture, i think the voltage divider is missing...
        10-06-2023, 02:05 AM
      • Xenon-Codex
        Volume potentiometer loudness tap bypass?
        by Xenon-Codex
        I salvaged a Sony TA-F170 with broken volume potentiometer. It has a special pot with a loudness tap in the middle, of course not available anymore.
        Is the loudness somehow possible to get to work, at least constant instead of variable? I have a regular potentiometer which works, but the loudness does not.​
        01-16-2024, 01:53 PM
      • dfear
        hitachi 75hl16t64u - not responding to remote control
        by dfear
        I have a hitachi 75hl16t64u tv in for repair and it is driving me crazy.
        It came in for a power issue which I have finally resolved by replacing the power supply.
        The current issue is that the TV does not respond to the remote control. I have replaced the IR sensor board with a used one but the fault persists.
        Anyone have a clue how to fix TV?
        FYI: I have checked the remote work s by pointing it at my camera on my phone....
        09-02-2024, 12:15 PM
