e701i-a3 no picture but backlights
Re: e701i-a3 no picture but backlights
Ok, after testing the voltages with the panel connected, i found that with only the right ribbon disconnected, all power in the t-con board dropper to zero except for the 100 cap which only drops about 1 volt. With only the left side disconnected all of the power in the t-con board drops to zero including the 100 cap. But with both sides disconnected i found that the power stays the same. Do you thing any of the components on the bottom board, such as any of the resistors, are bad, causing it not to work?Yes you should see the same voltages with the t-con connected to the panel. That is if the panel is not taking down the t-con. However there is always the slight possibility that you could have problems with the mainboard causing a no picture condition however voltages are present. And then there's always a slight possibility that both side drivers on the left and right could be bad. Do you have some kind of image being projected to the TV not just the black screen with a no signal? It would be easier to plug in an HDMI and use the input button to cycle to that port and listen for sound before you go any further then you can disconnect both bottom corner tabs plug in each side individually to the t-con and see if you get some image at all.
I also was able to get a couple vertical lines with both ribbons disconnected.Comment
You will get vertical lines if neither side is connected. This is normal because the horizontal drivers are not being regulated or controlled to send a horizontal picture matrix to the LCD panel so the panel does not understand what to do with the horizontal frequency. It's starting to sound like both sides of your panels horizontal tabs are bad sadly. This panel cannot run with both sides disconnected or you see the outcome with just the vertical stripes. Without physically having my hands on it I can tell you that this sounds like the best scenario here. What I would do now is physically inspect each tab with a very good bright light and a magnifying glass see if you see a tab that looks damaged or melted on both the right and left side.Last edited by freakaftr8; 04-16-2017, 12:45 AM.Did I leave the soldering iron on?Comment
two dumb questions, first what signal are you inputting in / on. Next, are the only cables you are "playing with" on /related to the tcon?Ok, after testing the voltages with the panel connected, i found that with only the right ribbon disconnected, all power in the t-con board dropper to zero except for the 100 cap which only drops about 1 volt. With only the left side disconnected all of the power in the t-con board drops to zero including the 100 cap. But with both sides disconnected i found that the power stays the same. Do you thing any of the components on the bottom board, such as any of the resistors, are bad, causing it not to work?
I hope you have more fet's ... :-)Comment
yes, the only cable o have messed with are the two white ribbons on each side of the tv and the two connecting to the bottom of the t con.
I also checked each of the tabs on the left and right sides, but they look perfect to me (compared to the pics that i have saw of bad tabs).
Any advice?Comment
Okay this is going to get a little Advanced but should be pretty simple. On each side you have basically an upper horizontal board and a lower horizontal driver board connected by a small flat white ribbon cable connecting the upper to the lower boards. This will be on both sides. What you're going to do is disconnect the little white ribbon cable that is connecting the upper to the Lower Side drivers on both sides . Then hook up the white t-con cable on the right side first see if you have one half lower picture. If you do then disconnect that side and then try the left side and see if you have the lower half of the picture working. At least we'll be able to tell if the lower drivers or the upper drivers are shorted are in the horizontal side drivers. This you will be doing while both corner ribbons are connected connecting the lower bottom vertical drivers to the lower side bottom driversyes, the only cable o have messed with are the two white ribbons on each side of the tv and the two connecting to the bottom of the t con.
Any advice?Last edited by freakaftr8; 04-16-2017, 08:40 PM.Did I leave the soldering iron on?Comment
you didn't answer my first dumb question... what signal are you inputting.yes, the only cable o have messed with are the two white ribbons on each side of the tv and the two connecting to the bottom of the t con.
Any advice?Comment
Ok, so i decided to re-seat all of the connectors along the sides of the tv just to be safe. After doing so i found that the power in the t-con board no longer drops to zero with only the right side connected (looking at it from the front).Okay this is going to get a little Advanced but should be pretty simple. On each side you have basically an upper horizontal board and a lower horizontal driver board connected by a small flat white ribbon cable connecting the upper to the lower boards. This will be on both sides. What you're going to do is disconnect the little white ribbon cable that is connecting the upper to the Lower Side drivers on both sides . Then hook up the white t-con cable on the right side first see if you have one half lower picture. If you do then disconnect that side and then try the left side and see if you have the lower half of the picture working. At least we'll be able to tell if the lower drivers or the upper drivers are shorted are in the horizontal side drivers. This you will be doing while both corner ribbons are connected connecting the lower bottom vertical drivers to the lower side bottom drivers
I was also able to get a picture on screen where half of it was black and the other half was white, but i didn't have anything connected to the tv.
However, the left side is still causing the zero volts in the t-con board.
I also tried what you mention before, and with the left upper board disconnected i still didn't get a picture.
And to answer your question budwich, I did not have anything connected to the tv... so no input.
I can post pics if you need them, and how would i tell what input channel the tv is on if i were to connect something to it.Comment
first thing I would do is put on my glasses... :-)
make sure you always know that the cables are connected properly as they can easily be "misaligned". Anyways, as for input, I was asking because if you don't input something, then you need to "create an image"... so you need to hit things like menu on the remote and be aware where to look on the screen as to where a picture might be especially when you may only be seeing "half screens".... thus if you see nothing on one side, it could be because there is nothing being displayed on that side.
Further, it appears that now you are finally getting somewhere as "normally" a disconnected tcon cable will generate a white screen on the side that has been disconnected.
I don't understand what you mean by "I was also able to get a picture on screen where half of it was black and the other half was white, but i didn't have anything connected to the tv." what "picture" are you seeing if you had nothing connected??????
My guess right now is that if you disconnect the left side corner cable (at the bottom of the panel... going between the side edge board and the bottom edge board) and leave the tcon fully connected, you will get a picture on the screen.Comment
Yes that is correct, and by picture i just meant that i saw half of the screen black and half white.first thing I would do is put on my glasses... :-)
Also im not for sure what is going on with the boards on the right side of the screen. Any time i touch or bump them the bottom half of the screen gets distorted. I was able to get a somewhat clear view of "no signal" but i had to hold the board at a weard angle for it to show up.
Do you think there might be a shortage in one of the ribbons leading to the sceen?Comment
well!!!! based on the picture, your issue appears to be on the left side.... as you can see the horizontal "issue". As suggested, with the current "setup" that gave your that picture, hit the menu button for the tv... what do you get on the screen?
Further as suggested, disconnect the lower left corner cable (as described previously), input a signal, hit the menu key whatever, what do you get?Comment
Actually, my first comment should have been... give us a picture of the back of the set showing us exactly what you have disconnected / connected to get the picture that you posted as I am confused.... I don't see any white screen.Comment
Ok TRImmortal please provide an image on the screen now. Something besides a no signal, so we can have a good look at the picture with video supplied. Well go from there.Did I leave the soldering iron on?Comment
I've had similar issues as everyone and I've gone through a couple Tconns now so I want to make sure I don't screw this up again. Standard scenario as the rest - black screen, backlight works, audio works. So replaced Tconn first time hoping that would do it, plugged everything back in and died again within 2 minutes of use.
Tried new replacement Tconn and checked output voltage seemed good. After reading more, I plugged one output ribbon in at a time from the Tconn, choosing left side to connect first. Turn on and picture shows up on that half the screen while the non connected side is black. Saw menu and looked ok. Then I disconnected left side, connected right Tconn ribbon and saw the reverse, with non connected half being black again and saw the vizio logo looking a bit faded on startup but visible on the right side, and then Tconn died again.
I assume all signs point to right side being bad, but I did try to look at the driver chips on both sides of the tv and saw nothing obviously burned. I guess I just want to be sure there's nothing else to check first before I attempt plugging in the new Tconn I just got. I saw something about leaving both tconn output ribbons connected but disconnecting the corner ribbons instead? (In my pic that would be 2R/L or 3R/L). Is there an advantage to doing that for troubleshooting?
Any advice is welcome. Hopefully my annotated pics can help others for future clarification, please feel free to use as needed.
Note: Annotations are labeled as looking at the back of the TV upright:
Link to album:
http://imgur.com/a/LpUqSComment
Guess I can't edit posts, just thought I'd further clarify pic:
General overview of back of TV. Upside down as you can see, hopefully labels can help. From Tconn ribbons (yellow) to connector (1R/L) then from board on the bottom (blue) to corner ribbon (pink) to side drivers (green). Connectors are shown at arrow locations 1, 2, and 3. Annotations are labeled as looking at the back of the TV upright:
Link to album:
http://imgur.com/a/LpUqS[/QUOTE]Comment
one reason for doing the "corner cable disconnect" while having all other cables connected is that you get a "full display". IF you are wise and input a known test pattern (smpte color bars or equivalent), you can then readily analyse the screen to look at what is happening... if anything. This may confirm your findings or possibly point to other issues which need further investigation.Comment
			by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
 - Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
Assuming...7 Photos -
			by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
			by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
			by kcaHello all ~
I got the display to work by taping off several traces of the right-hand side ribbon cable on the TCON that leads from TCON to PANEL. However, despite dozens and dozens of attempts to find the right combination / range of traces taped... - Loading...
