PS50B430P2WXXU vertical grid lines on screen
  • comptek
    • Aug 2013
    • 606
    • uk
    Hi guys someone has been asking me if this is repairable
    the unit isnt with me so i cant give measurements of voltages etc just need advice or pointers please
    see pictures there seems to be symetrical vertical lines on screen whilst on in put and on no input and menu showing, lines are overlaid on the menu too
    Many thanks Gary
    [/URL][/IMG]
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: PS50B430P2WXXU vertical grid lines on screen
    Looks like a missing Lvds line, doesnt look like panel. Checked Lvds and all other connections ?
    • comptek
      • Aug 2013
      • 606
      • uk
      Thanks Reecey so basicly reseat all cables to be sure ?
      thanks mate
        Control board fault. Run test patterns on control board to confirm. Panel OK.
        • comptek
          • Aug 2013
          • 606
          • uk
          tom you mean bridge the link on control board with main board disconnected yes ?
            Yes
            • comptek
              • Aug 2013
              • 606
              • uk
              cheers Tom will check yours and reeceys ideas and get back with an update
              Thanks Guys
              • Hamie
                • Apr 2014
                • 1383
                Out of interest, if you heat up the control board with a hairdryer do the lines go away?
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Let us know also try Hamie's idea.
                  • comptek
                    • Aug 2013
                    • 606
                    • uk
                    will do thanks guys
                    i think i may have a board too
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Any update Gaz ? Have the A430 coming in with the same issue too
                      • comptek
                        • Aug 2013
                        • 606
                        • uk
                        never got to see it Reece sorry
                        • Stanley1843
                          Screen Display Vertical Multicolor Lines
                          by Stanley1843
                          Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
                          06-29-2024, 11:54 AM
                        • Firentiosi
                          1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
                          by Firentiosi
                          Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
                          The issues are as follows: the...
                          11-27-2024, 12:33 AM
                        • Ancient1
                          Strange LG TV issue : Image vertical lines in black screen
                          by Ancient1
                          Hi
                          Asking for a friend.
                          I'm used to black vertical line in otherwise good image - probable solution is a rubber to push and tighten the COFs bonding.
                          but here its the opposite !
                          TV has new T-con = same issue
                          A missing panel voltage would have global effect
                          So , what should one do ? how can I find where the fault is ?
                          Thanks !...
                          02-05-2025, 03:37 PM
                        • Kambi13
                          Samsung LE32C530F1W with vertical lines on Screen
                          by Kambi13
                          Hello all, I'm dealing with a Samsung LE32C530F1W that now has vertical lines on the right side. It started with a ghost image on the top of the screen and then I tried the old trick of masking a few contacts in the flat cable that connects the T-Con board to the screen with some tape. It worked for a while and now out of the blue it turned into what you can see in the pic. I was able to get my hands on a known good T-Con board but the problem still persists. Now, what I've noticed is that the cooper colored flat cables that are directly connected to the screen itself are very hot to the touch...
                          09-15-2022, 07:48 AM
                        • ItalianSat
                          LCD SAMSUNG LE40A656A1CXXE - Vertical Lines on Half of The Screen?
                          by ItalianSat
                          Hello Everybody,
                          I have a 40 inch LCD SAMSUNG LE40A656A1CXXE. Its problem is that there are Vertical Lines on Right Half of The Screen.
                          Interestingly enough, when I move my mouse (in the case if connected to a PC) or when I am watching the TV, lines also move. At first appearance, I had thought that the problem might arose from loose vertical ribbons (COF), but when I opened up the TV for further investigations, I realized that the problem cannot be solved by touching them.
                          Moreover, I detached the T-CON board for a new round of investigation. I personally...
                          06-28-2022, 06:02 AM
