toshiba 46sl417u lines on screen help
  • mattstolte
    • Dec 2013
    • 612
    • usa
    So i got this tv in my shop wouldn't turn on had a bad main. Could find a replacement so I sent to moduslink for repair and return. So i get it tv works but has lines vertical all over it. Don't have a good picture put here is what lines look like. Do you think its bad main?
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4542
    • Italy - Milan
    Re: toshiba 46sl417u lines on screen help
    I think it could have a bad connected lvds cable, since some pins are for odd pixels, others are for even ones only on fullhd screens. Bye.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Is the mainboard the correct one for that panel ?
        I have seen this on "100Hz" sets where the EVEN or ODD LVDS connection is missing (usually marked) this can be e.g. if one connector not properly seated or damaged or perhaps a bad main board.
        • mattstolte
          • Dec 2013
          • 612
          • usa
          thanks tom i found a damaged lvds cable
          • mattstolte
            • Dec 2013
            • 612
            • usa
            Ok so I did find on one of the lvds cables had a burnt strip so I replaced both and still getting same thing. I even sent it back to modus link pts cause they repaired the main board and they said it worked fine in there set. And they tried to tell me I needed new lvds cable so I bought both brand new and still same issue. Is it possible tcon?
            • mattstolte
              • Dec 2013
              • 612
              • usa
              • mattstolte
                • Dec 2013
                • 612
                • usa
                Anybody
                • Stanley1843
                  by Stanley1843
                  06-29-2024, 11:54 AM
                • jeyoung12
                  Samsung QN50Q60t lines on screen
                  by jeyoung12
                  Hi all
                  I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                  My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                  This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                  It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                  So....i don't know what end of the C ribbon to work with...
                  02-26-2024, 10:38 AM
                • Ryan.man
                  by Ryan.man
                  02-04-2025, 12:23 PM
                  09-06-2024, 05:27 AM
                • kdaniel
                  Hitachi 58HK6100U - Horizontal Lines (Bottom third of the screen)
                  by kdaniel
                  As stated by the person I collected the TV from, it just stopped working overnight. However, I still gave it a go to try and repair it.
                  There is a thread on the same TV but with slightly different issues where they had to tape connection points on the ribbon cable, so I want to see if this is repairable by any chance.
                  After bringing it home and plugging it in, the TV turned on with its backlight working but had no picture. After removing the back cover, the first thing I tried is to unplug one of the ribbon cables and the situation is as follows.
                  Left...
                  11-16-2022, 09:23 AM
