TX-P50GT30E Replace SS Board
  • picciolino
    • Sep 2015
    • 8
    • italia
    Hi All,
    my tv is broken the SS-Board is dead (8 blinking led).
    I tried to repair it but the Mos and the diode are good.
    I need your help for replace this board.
    I search the SS BOARD TNPA5331AG (board Broken)but I found on the shop jimmy store only the TNPA5331AJ.
    It s possible to change the dead board "AG" with the new model board "AJ"?
    What is the difference?
    The board seems the same in the picture.
    I suspect that the new board AJ is better than old board AG.
    Can you help me?
    Thank a lot
    Andrea
  • sordids999
    • May 2013
    • 2149
    Re: TX-P50GT30E Replace SS Board
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • picciolino
      • Sep 2015
      • 8
      • italia
      Thank you a lot for your help,
      below you can find the picture.
      Sorry for the bad resolution, tomorrow i will resend it.
      • tw2005
        • Oct 2011
        • 6458
        AJ should be fine it's also 50GT30 in the US. Looking at it the only difference will most likely be the panel connector. Appears to be a flip up type on yours and on the AJ the tabs slide out from the front, insert ribbon then press the tabs back into secure it.
        No it won't be any better, same board really just different hardware used.
        • picciolino
          • Sep 2015
          • 8
          • italia
          Thank you
          you think that will be possible to insert the panel flat cable in the new connector of new board (AJ)?
          • tw2005
            • Oct 2011
            • 6458
            Originally posted by picciolino
            Thank you
            yes
            • picciolino
              • Sep 2015
              • 8
              • italia
              yes
              Thanks a lot,
              I will let you know
              Ciao
              • picciolino
                • Sep 2015
                • 8
                • italia
                Thanks a lot,
                I will let you know
                Ciao
                Hello i finally changed the SS board (bought from shopjimmy) and when i plug it into my tv Showed 8 LEDs.
                I verified the cable side and the flat D board
                I saw that the cable flat was oxidized and after cleaning my television set is turned on.
                thank for all
                • tw2005
                  • Oct 2011
                  • 6458
                  thank for all
                  Sometimes they fight to the end
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                  • Hakuu
                    by Hakuu
                    Hi There,
                    More Details
                    TV Model - LG OLED77G1PUA
                    07-12-2023, 02:37 PM
                  • jb_Bak
                    by jb_Bak
                    CN6401
                    Pin 01 NC
                    Pin 02 NC
                    Pin 03 "BL_ON": 0V
                    Pin 04 "N/C"
                    Pin 05 "STBY 3.3V": 3.5V
                    Pin 06 "GND": N/C
                    Pin 07 "AC_OFF"...
                    09-27-2021, 04:52 PM
                  • canadaboy25
                    Panasonic TC-P54VT25 No image. A or D board?
                    by canadaboy25
                    I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                    The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                    I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                    01-17-2021, 01:06 AM
