Lg 47ln5750 led tv
  • tech2014
    • Aug 2014
    • 807
    Lg 47ln5750 led tv
    I have an led tv with sound but no picture. When the power comes on, there is picture for about 2 seconds then goes black. I did the flashlight test and there is video. I tested all the voltages and they were all there. I noticed that at connector P801, the voltages jump to about 150V for the short time the backlight is on, then drops to 80v and stays consistent at 80V. This connector P801 has 2 (LED+) pins and 2 (LED-) pins .I assume that P801 is connected to the LED strips in the panel. When power is applied, I get 80v on LED+ pins and around 22-25V on the LED- pins. With the voltage starting high then dropping, would this be a bad driver circuit in the power supply, or is the panel the problem.
    Here are 2 pics of the tv. Pic 1 is the connector P801 and pic 2 is of the back of the tv with circuit boards. I also included a schematic of the power supply below
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Lg 47ln5750 led tv
    https://m.youtube.com/watch?v=Bf5T2wwtydY
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Watch this sounds like a similar issue.
      • tech2014
        • Aug 2014
        • 807
        When I turn on the tv in the dark it appears that all the LEDs are lit. Is there any way to force the LEDs to stay on ?
          You have open circuit in one of the LED string that is why it goes up 150VDC.
          • tech2014
            • Aug 2014
            • 807
            ok. How come the LEDs all seem to light up at power up? So its for sure a panel problem then?
            • mattstolte
              • Dec 2013
              • 612
              • usa
              Take the panel out and watch the leds light up there may even be one out you wont tell unless you have panel out and watch them light up these 47 lg led are common for bad leds. I have some led strips for sale for it. I have done about 5 repairs on these models within last 3 months
              • tech2014
                • Aug 2014
                • 807
                ok so its a common problem on these TVs. I will take out the panel then. Thanks for the help.
                  You have two set of LEDs with two driver circuits as you can see the schematic, so one set will still lights up but another one did not so the protection circuits kick in.
                  • tech2014
                    • Aug 2014
                    • 807
                    I forgot to mention that when I disconnected the connector that goes from the power supply to the LED panel, the voltage still jumps up to about 160V then settles down at 80V. Wouldn't this be a power supply problem then?
                      "I forgot to mention that when I disconnected the connector that goes from the power supply to the LED panel, the voltage still jumps up to about 160V then settles down at 80V. Wouldn't this be a power supply problem then?" Both LED+? OR just one of the two?
                      There are TWO LED + outputs, check both of them one at a time every time you turn on the TV and report back what you read on BOTH LED +, then do the same again with the LED connector NOT in place and report the readings again at each LED+ pins, you must do that with the probe connected to the LED+.
                      The Voltage drops down when the error is detected OVER VOLTAGE CONDITION DUE TO NO LOAD so the boost converter is shutdown that is why you only see 80VDC. It is constant power supply.
                      Did you not look at the schematic to see what is going on? Look at PDF page 20.
                      "Wouldn't this be a power supply problem then?"
                      You can replace the power supply board if you want because I do not know how much more explanation you want.
                      • tech2014
                        • Aug 2014
                        • 807
                        both LED+ voltages jump up to around 160v then drop back to 80V. I am going to test the LED strips today. thanks for the help.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Have you watched the video I sent the link to ?
                          • tech2014
                            • Aug 2014
                            • 807
                            yup I watched it and it was very helpful, thank you very much.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Ok no worries does your meter have a min max mode ?
                              • tech2014
                                • Aug 2014
                                • 807
                                yes it does
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  Did you do a similar test to what Norcal did in the video and compared the two connectors ?
                                  • tech2014
                                    • Aug 2014
                                    • 807
                                    yup I got about 50V on each return.
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      Hmm its possible that you don't have a shorted led but there are several that have failed which is tripping the protection circuit due to change in current, seen it on a 40" toshiba.
                                        50V with LED connector in place at the LED -? 50V means that BOTH the PWM POWER MOSFETs are barely turned on.
                                        Also you are saying you are getting 160VDC on one of the LED+ or both LED+ WITH the LED connector in place?
                                        "I get 80v on LED+ pins and around 22-25V on the LED- pins." so the peak hold shows 50V then?
                                        "both LED+ voltages jump up to around 160v then drop back to 80V. I am going to test the LED strips today. thanks for the help." With or without the connector in place?
                                        The key point I am looking for is the Voltage with load and no load.
                                        • corrize
                                          Where to find a very small fpc connector 0.3mm between 2 pins ?
                                          by corrize
                                          Hello, I search this connector (oxydated).
                                          It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                                          I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                                          I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                                          Do you know how to find this connector please ? What is the exact name for find it ?
                                          08-06-2024, 05:25 PM
                                        • bussincaps
                                          MacBook Pro Mid-2014 A1398 Retina LED Controller Connector [First Repair (Disaster)]
                                          by bussincaps
                                          Hello All,
                                          tl;dr: minimal electronics experience and my first repair, lifted 8 pads off the laptop display LED controller board when attempting a connector replacement, options are attempting pad repair or jump wiring.
                                          Laptop Model: MacBook Pro 15 Mid-2014 Retina, A1398 MGXA2LL/A
                                          eDP Display: Samsung LSN154YL01-A02, assembly sold as Apple part 661-8310
                                          Soldering Equipment: Hakko FX-888D w/ T-18 tips (Chisel, Conical, Bevel types)
                                          I needed to replace the 30-pin I-PEX Cabline connector (labeled J8300 in the Apple 820-3662 mainboard schematics),...
                                          08-03-2023, 12:57 PM
                                        • araxnido
                                          Programming KBC IT8987VG ASUS TUF FX506L RT809F+PEB
                                          by araxnido
                                          Dear friends, I want to share my experience repairing an ASUS TUF FX506L gaming laptop motherboard: DABKXDMB8E0_F_BKXD. Boardview and schematic are available, as well as the BIOS and ITE ROM.
                                          When the customer brought in this laptop, it was initially dead; it showed no signs of booting for any reason. After hours of measurements, checking each stage, MOSFET, and seeing if there was a short circuit in any capacitor, I discovered a strange 0.7V leakage voltage on the 3V_S5 rail, particularly on the PL9 coil, with the board not powered on. There were 3V_LDO and 5V_LDO voltages, which...
                                          06-10-2025, 09:26 PM
                                        • jagg
                                          Hp pavillion x360 15-CR0087CL BOARD: LEIA_15 KBL UMA 17881-1B missing component
                                          by jagg
                                          Hello friends, I have this laptop which would not turn on, I detected that the 3v and 5v source circuits were damaged and a 6 pin circuit in short, which I suppose are diodes, I'm not sure since there is no diagram, I removed this circuit and the sources and there is no longer a short, the new 3v and 5v sources were installed and the laptop now works, the problem is that I don't know what this 6-pin circuit is, I think it has to do with the battery, since the operating system does not detect the battery, I measured the IC pins and they go to these pins of the battery connector, does anyone know...
                                          04-23-2025, 12:48 PM
