Lg 47ln5750 led tv
  • Agent24
    I see dead caps
    • Oct 2007
    • 5035
    • New Zealand
    #41
    Re: Lg 47ln5750 led tv
    I am not sure, I always keep them in the same order when I take them out to avoid that problem...
    http://nuigroup.com/forums/viewthread/14133 2nd image may help. It looks like that silvery\shiny looking sheet needs to go between the other two.
    -David VanHorn
    • tech2014
      • Aug 2014
      • 807
      ok thanks Agent24
      • johnboy1313
        • Nov 2012
        • 1959
        I just picked one of these up today. I'm not sure what the fault is yet, but if I have to get into the panel, I'll let you know the order.
        • gglgtv
          • Feb 2016
          Were you able to repair your 47LN5750 TV. I have same model with same problem.
          • corrize
            Where to find a very small fpc connector 0.3mm between 2 pins ?
            by corrize
            Hello, I search this connector (oxydated).
            It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
            I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
            I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
            Do you know how to find this connector please ? What is the exact name for find it ?
            08-06-2024, 05:25 PM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • bussincaps
            MacBook Pro Mid-2014 A1398 Retina LED Controller Connector [First Repair (Disaster)]
            by bussincaps
            Hello All,
            tl;dr: minimal electronics experience and my first repair, lifted 8 pads off the laptop display LED controller board when attempting a connector replacement, options are attempting pad repair or jump wiring.
            Laptop Model: MacBook Pro 15 Mid-2014 Retina, A1398 MGXA2LL/A
            eDP Display: Samsung LSN154YL01-A02, assembly sold as Apple part 661-8310
            Soldering Equipment: Hakko FX-888D w/ T-18 tips (Chisel, Conical, Bevel types)
            I needed to replace the 30-pin I-PEX Cabline connector (labeled J8300 in the Apple 820-3662 mainboard schematics),...
            08-03-2023, 12:57 PM
          • araxnido
            Programming KBC IT8987VG ASUS TUF FX506L RT809F+PEB
            by araxnido
            Dear friends, I want to share my experience repairing an ASUS TUF FX506L gaming laptop motherboard: DABKXDMB8E0_F_BKXD. Boardview and schematic are available, as well as the BIOS and ITE ROM.
            When the customer brought in this laptop, it was initially dead; it showed no signs of booting for any reason. After hours of measurements, checking each stage, MOSFET, and seeing if there was a short circuit in any capacitor, I discovered a strange 0.7V leakage voltage on the 3V_S5 rail, particularly on the PL9 coil, with the board not powered on. There were 3V_LDO and 5V_LDO voltages, which...
            06-10-2025, 09:26 PM
          • jagg
            Hp pavillion x360 15-CR0087CL BOARD: LEIA_15 KBL UMA 17881-1B missing component
            by jagg
            Hello friends, I have this laptop which would not turn on, I detected that the 3v and 5v source circuits were damaged and a 6 pin circuit in short, which I suppose are diodes, I'm not sure since there is no diagram, I removed this circuit and the sources and there is no longer a short, the new 3v and 5v sources were installed and the laptop now works, the problem is that I don't know what this 6-pin circuit is, I think it has to do with the battery, since the operating system does not detect the battery, I measured the IC pins and they go to these pins of the battery connector, does anyone know...
            04-23-2025, 12:48 PM
