help with plasma lg 42pc5d no picture but powers on
  • mattstolte
    • Dec 2013
    • 612
    • usa
    tv turns on just no picture, would it have to be a ysus? I have a hard time figuring out plasmas not sure the best way to figure out what is the problem
  • Hamie
    • Apr 2014
    • 1383
    Re: help with plasma lg 42pc5d no picture but powers on
    Usually this would be a failed ipm on the y-sus.
    Is the fuse open?
    Vsc and -vy voltages?
    These are Measured across a couple of marked resistors.
    • mattstolte
      • Dec 2013
      • 612
      • usa
      This is what i gathered so far, well first off tv turns on soon as i plug it in and the buttons will not shut it off and i dont have a remote to try. So makes me thing main fault? No open fuses.
      Va 59
      vs 192
      vz bias 140
      -yz 160
      i dont know what ysc is or where to check that thanks for your help so far and sorry about the caps. My button got stuck
      • Hamie
        • Apr 2014
        • 1383
        Ok connect the 2 holes marked autogen on the control board.
        Disconnect the lvds cable that connects this board to the main board.
        Power on and see if you get test patterns.
        Autogen located here:
        • mattstolte
          • Dec 2013
          • 612
          • usa
          Ok i got the auto gen and test pictures appeared on screen so does that mean bad main?
          • Hamie
            • Apr 2014
            • 1383
            Yes, almost certainly.
            • mattstolte
              • Dec 2013
              • 612
              • usa
              What's crazy is i had a newer lg plasma i fixed couple months ago kept cutting in and out and when picture would cut out i would still have sound. And I did the auto gen and test patterns appeared and I ordered new main and still did it and what's weird it happen to be the digital main fault
                The autogen test bypasses the main board and part of the control board. If the autogen works, the PSU, Z-sus, Y-sustain, panel, buffers etc are all working ok. There is a very small chance the control board LVDS processor is faulty but in almost all cases the main board is the only fault.
                • Shane711
                  • 493
                  I have this TV LG 42PC5D today and I have the same problem in this post. So I did the autogen test, tried a wire clip first but it would not work so I soldered it in and presto, the TV turns on with the test patterns showing all over the screen, nice nice nice! TV works great so I guess I must have a bad main board. The TV will not turn off either. So I am going to order a used main board and see what happens.
                  • tvtimmy
                    • Mar 2015
                    • 1160
                    • usa
                    You should be good to go. Dont forget to remove the soldered in jumper.
                    • Shane711
                      • 493
                      OH YEA! I removed the soldered jumper and got the main board from eBay for $20 & free shipping. Hope they send me a good board.
                      I have at least another 200 TVs to fix. I will try to get them all done by Thanksgiving.
                      • KYBOSH
                        Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
                        by KYBOSH
                        Saved this beast from the landfill this weekend.
                        Manfactured July 2013 in Mexico.
                        I love working on plasma TVs.
                        Its been a while but I was lucky enough to find 2 this week.
                        The TV powers on and stays on but no picture. Havent checked for sound yet.
                        No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
                        Will start troubleshooting tonight.
                        10-17-2024, 01:17 PM
                      • KYBOSH
                        Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                        by KYBOSH
                        Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                        No picture but you hear the TV static (white noise) playing loud and clear.
                        The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                        But it seems they didn't get too far and just left it.
                        When I first took a look I was amazed at how pristine the inside looked.
                        Its as if the TV had been in a time capsule.
                        Caps looked like they were just pulled off the self.
                        Copper coils had no sign of corrosion on...
                        02-01-2023, 11:10 PM
                      • csmith
                        Vizio D50u-D1 Powers up no picture
                        by csmith
                        I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
                        Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
                        supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
                        issue. Set will power up with remote but not power off....
                        07-11-2025, 11:52 AM
                      • sergio_av
                        Acer Aspire E5-571G-52NH powers on, no picture. PCH_ENVDD goes off and on.
                        by sergio_av
                        Hi, I'm unexperienced with troubleshooting and I'm not sure how to proceed with this laptop.
                        Motherboard is A5WAH LA-B991P I think, i5-5200U and nvidia 820m.
                        When I received the laptop, CMOS battery had 0V. I took it out and all the testing has been done without a CMOS battery and without the main battery plugged in, I haven't been able to see physical damage, burnt or missing components with a quick visual inspection, and no shorts were found.
                        Laptop charges the battery, powers on when ON button is pressed when powered from charger and when powered from the battery, but...
                        01-01-2025, 05:27 PM
                      • canadaboy25
                        Hitachi 55HDX99 Plasma Powers on but no picture
                        by canadaboy25
                        Hey guys, I recently acquired a Hitachi 55HDX99 plasma TV that doesn't work. The TV powers on and eventually goes into standby which is indicated by the blue power led changing to orange. If I plug a VCR into it to keep it awake, I can feed an audio source in and it will play the sound no problem. The volume controls on the TV work as well so it is obviously just a display problem.
                        I found the Hitachi service manual online which is also hosted on tom66's manual archive. Compared to the Panasonic service manual I had for the last plasma I worked on, this one is underwhelming to say...
                        03-22-2019, 12:06 AM
