My Samsung ue32f5000ak has had a blank screen but had sound and i have got to the point where i have found the problem which was a faulty LED on the LED strip for the back lighting but i was wondering if I bridge the connection of the led so it doesnt use the LED would it cause any additional damage? or should i just wait and order an led?
My Samsung ue32f5000ak has a blank screen but has sound
Tags: None
Re: My Samsung ue32f5000ak has a blank screen but has sound
You can us 5 1N4007 Diode in series to simulate the Whit LED Vf or use 3.3V 3W Zener connected in reversed. U use 1N didoed because I have tons of them.
Make sure to leave the legs long and the body touch the chassis to help dissipate the heat because it gets hot.
https://www.badcaps.net/forum/showthread.php?t=46403Attached FilesNever stop learning
by mrtekHi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...6 Photos
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
by mecha1166KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
by ChrissygizmoHello everyone, I’ve just been given a Samsung UE55JU6800K smart tv as it had white spots on the screen due to the led lenses falling off. After refitting them & putting the tv back together I thought it was a nice easy fix for a free bedroom tv , then I tried it before screwing the back into place. I realised that the right side of the screen was darker than the other side, I removed the screen again as I thought the backlights had failed but they are fine.
I put the screen back in place & turned it back on . The screen seemed to be ok again but different screens on the same... -
by mar1inHi everyone,
I've got this Samsung here that would be stuck in a boot loop.
After opening up and doing the tape block method, I was able to get it to turn on and play sound from the HDMI input, but with a blue screen.
Does that mean there is another combination of pins that I need to block in order to get a picture, or is there something more serious, faulty mainboard or faulty panel?
Thanks in advance - Loading...
