Panasonic TC-P65ST30 - 7 lights, possible screen failure?
  • carsnottvs
    • Sep 2015
    Hi guys, new to the forums. I'm definitely not an experienced electronics guy, but I'm not a newbie to technical problems and diagnosis (automotive technician).
    I picked up my coworkers' TC-P65ST30 for free because he didn't want to deal with the 7 blinking lights of death. After some reading in other threads, I've disconnected the SU/SD boards and jumped the SC50 connector, and get a solid power light, with no picture. From what I understand, that narrows it down to the SU/SD boards, and/or the screen itself taking out those boards.
    My coworker claims that he had someone else (he's being very vague and/or cagey about this) replace "all 3 boards on the left side." I assume he means the SC, SU, and SD boards. I've found a couple of hints about bad screens taking out the SU and SD boards on other Panasonic models, but I don't find much info on my particular model.
    How likely is it that I might have a bad screen? I found used SU and SD boards (TNPA5347/5346) on Amazon from private sellers for about $36, so I'm tempted to throw those in and just go for it. Is there any more diagnosis I could do to eliminate other potential problems?
    Also, I've seen a lot of part numbers TNPA5346AC and TNPA5347AC. In automotive circles, this is usually a revision of an existing part, and can often be crossed over. Is that true of TV parts, or is it going to be a totally incompatible part?
    I appreciate your help here guys!
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P65ST30 - 7 lights, possible screen failure?
    The revision will be due to a different panel model and so is matched to it. i've only had a very quick look but comparing the 2 SD boards there a ceramic cap added to one so you'll probably get away with it but wold be better to get the right one or remove that cap off the AC version and that shold then make them the same.
    If you go to shopjimmy and look at the pictures enlarged on both boards and both versions you should be able to work out the differences which will be subtle I suspect.
    Check all mounting bolts on the SC and SS for security and good earths. On this series they changed the bolt type with no locking washers which have resulted in these coming loose and can be a reason for the boards blowing. Not sure if this has an affect on the buffers.
    always a chance of a bad panel you won't know unless these blow again quickly or it still has 7 blinks since the SC50 test passed that's a good sign the SC is ok.
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • Chrissygizmo
      Panasonic TX-48CX350B backlights but white screen , blank screen
      by Chrissygizmo
      Hi all, I’ve got a problem I hope someone can help me fixi.
      I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
      01-11-2025, 03:18 PM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • smic717394
      by smic717394
      07-25-2024, 10:16 AM
    • Audeze
      Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
      by Audeze
      I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
      Does...
      10-06-2024, 08:54 PM
