Samsung LE26R87BD power cycling
  • smeghead69
    • Sep 2015
    • uk
    Hi all!
    I have a samsung 26" LCD it works fine for a while but when it warms up it turns off and starts to power cycle. All the caps are fine and all the rail voltages are fine. I tried to unplug the inverter board and the set stayed on fine then so i replaced the inverter but this did not fix the problem. I've seen a few post on the net with similar issues but none with any resolution yet. does anyone have any suggestions as to where to go with it next?
    If i remember correctly when it cycles the standby voltage still remains but all the others drop out and return again a few seconds later. When the set turns back on it doesnt display any input signal. does this suggest its a main board problem rather than PSU?
    Re: Samsung LE26R87BD power cycling
    So if the standby Voltage is staying steady but the TV is cycling on and off, then you need to look at the PS-ON signal from the main board to see if it is going HIGH and LOW, <1VDC = OFF, >2VDC = ON, it should stay HIGH after power switch is activated, and goes LOW when power switch is turned OFF.
    • hispeck
      • Aug 2015
      • 258
      • nigeria
      Good day. Please i will like to continue with this topic because am having same issue now with the same model of samsung. Mine will goes off and ps_on will be 0v then when is on the voltage is on 3.4v
      • valvashon
        Samsung UN55FH6030: random power cycling
        by valvashon
        Samsung UN55FH6030, perfect size for my office and does OTA well but isn't a smart TV. That's OK because I am a TV station engineer and only need it for OTA monitoring.
        About a month ago it started power cycling itself once or twice a day and now it's nearly continuous once it's been on for a few minutes. Changing channels would really start it cycling and it would take several minutes to stabilize but now it's just doing it almost non-stop without changing channels.
        Once I disconnected the antenna I found that I could change channels with no issues. My guess is...
        10-20-2023, 09:59 AM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • Journey11
        Samsung TV won't turn on ... keeps cycling the power relay on & off
        by Journey11
        Hi All,
        First time posting here ... my name is Kevin but my friends call me Journey.
        I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
        After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
        It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
        07-04-2024, 02:44 PM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • high-tech
        Samsung UN55F7050AFXZA ver. TD01 power cycling
        by high-tech
        Hello everybody, I could use some help on this one... It's got me guessing...
        I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
        (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
        (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
        (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
        (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
        9. ground (PWM2) 10. 0.9 volts cycling...
        09-15-2020, 03:39 PM
