Vizio M420NV No Picture/No Sound
  • mlg1979
    • May 2015
    • 9
    I'm working on my mom's Vizio M420NV. She said it all started the other day when the audio stopped working so she turn the TV off. When she turned it back on it was hit or miss for the picture to stay on. Then finally wouldn't do anything.
    My diagnostics so far.....I see not visible damage or anything burnt on either boards. The VIZIO power light at the bottom of the TV is amber colored when off and white when powered on. There is no sound or picture or backlights. I have tested the power supply as much as possible with the tools I have. I have power on the primary side and no real power on the secondary side. If I test the connector going from the power supply to the mainboard the only voltage I have there is 5.3v on pins 1 2 3 which shows to be correct. Pins 8 9 10 are suppose to have 12v but do not.
    Is the power supply bad, or do I need to test something else?
    Mike
  • CapLeaker
    Leaking Member
    • 8352
    Re: Vizio M420NV No Picture/No Sound
    If not all voltage rails coming up from the PSU, then you would have to fix that first! Then I am not sure if not something else is going on at the main board.
    Check diode D120 on the PSU if it is shorted. That diode rectifies 12V.
    • jetadm123
      • 2169
      Your photo is too blurry to make out the writing, but on the power board wiring harness you should have a pin marked something like PS_ON? Appears you have the 5V standby voltage that the mainboard uses, but not the 3.3V signal the mainboard sends to turn on the power supply.
      • mlg1979
        • May 2015
        • 9
        I've attached a better pic.
        D120 has no voltage, but is that because that half of the board isn't powering up?
        The connector that runs to the mainboard the exact voltages are pins 1 2 3 5.3v pins 4 5 6 7 8 9 10 0v pin 11 .5v pin 12 3.2v pin 13 1.7v pin 14 .6v
        Hopefully this helps.
        • CapLeaker
          Leaking Member
          • 8352
          check D120 with your DMM in diode test. If it is shorted, it is bad.
          • mlg1979
            • May 2015
            • 9
            I removed the diode from the circuit to test, but I'm unable to determine which pin is the gate. Any help is greatly appreciated.
            • CapLeaker
              Leaking Member
              • 8352
              no gate. Its a "double" diode. Cathode is in the middle, so your negative lead goes there. Then measure the 2 outside pins. If its a short, its bad.
              • mlg1979
                • May 2015
                • 9
                Measures .200 on both sides, so I assume its not shorted. Is that correct? If that is correct where do I go from here?
                Thanks again for the help.
                • Andrew F. Ali
                  • Jan 2014
                  • 2450
                  • Trinidad & Tobago
                  I'm not seeing PS_ON pin. Would that be the REMOTE_ON/OFF pin?
                  • CapLeaker
                    Leaking Member
                    • 8352
                    What do you get on the remote on/off pin when you turn on the TV? I think the PSU is just off.
                    • CapLeaker
                      Leaking Member
                      • 8352
                      You may be able to force the PSU on manually by itself by using a 1k resistor and jump remote on/off to 5.3VSB
                      That should bring up the 12V as soon as you plug it in. You can take also another resistor, plug in the backlights and jump blon/off to 5.3VSB. That should then bring the whole PSU alive with the backlights on.
                      • mlg1979
                        • May 2015
                        • 9
                        I did what you said on putting a jumper from 5.3vsb to BL_ON/OFF and REMOTE_ON/OFF and everything works. So I guess that means its not getting signal from the mainboard to turn on. Where do I go from here?
                        • CapLeaker
                          Leaking Member
                          • 8352
                          Depending on your ability, time, money, equipment etc., either buy a board at SJ or trace and troubleshoot the main board. Maybe a fuse, voltage regulators, caps, diodes etc.
                          Scroll on top of this thread:
                          https://www.badcaps.net/forum/showth...999#post300999
                          • Sauktronics
                            • Mar 2017
                            • 4
                            I have the same problem wondering if anyone figured out the solutions to this.. If it's just the eeprom that would be great.. Let me know
                            • ggil44
                              Vizio M65-E0 No Picture, No Sound
                              by ggil44
                              Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                              09-03-2024, 08:30 PM
                            • TR103
                              by TR103
                              - it keeps rebooting
                              01-22-2025, 04:12 PM
                            • jord4231
                              Toshiba 37AV500A Regza TV good power supply no sound no picture
                              by jord4231
                              Hi Everyone,
                              I'm working on a Toshiba 37AV500A Regza TV.
                              The issue:
                              TV was working picture and sound went out. Green stand by light stayed on, It will respond to the power button being pressed (goes in and out of standby)
                              The TV will very intermittently work for around 40 mins then stop. This doesn't seem to matter if its hot/cold unplugged for a while etc.
                              I checked the PSU voltages and everything looked good.
                              No bulging caps or signs of heat.
                              24v aud = 24.41v
                              12v = 11.98v
                              5v = 5.062
                              p_o/f = Goes high...
                              03-29-2022, 09:21 PM
                            • Mgiffune
                              by Mgiffune
                              06-09-2024, 10:28 AM
