Distorded Picture Samsung LN40A500 Picture inside
  • gattaca714
    • Aug 2015
    • 4
    I started to receive this discolored screen on my Samsung LN40A500 TV.
    I thought it could have been the T-CON board based on what I read on here, but that turned out to be incorrect as the picture stayed the same quality.
    In the last year I have replaced the power supply and also the main logic board.
    Any leads on what this could be?
  • gattaca714
    • Aug 2015
    • 4
    Re: Distorded Picture Samsung LN40A500 Picture inside
    Bump before I toss this Samsung at the recycling center.
    • aaronwt6
      • Apr 2013
      • 855
      • US
      Personally I would be shocked if you find out that this is anything other than the T-con based on the picture you took. Best thing to do would be to test all the gamma voltages on the T-con and post them. If I'm not mistaken, there are 16 test points on this T-con (V400H1-C03). These fail frequently and my guess is that the one you purchased is also bad.
      • tvtimmy
        • Mar 2015
        • 1160
        • usa
        I just replaced the tcon in that set. Picture looked just like that. I went into the service menu and changed the ldvs setting from jedi or whatever it was to PDP and it was fine. It has something to do with the newer software, so they said. Hope this helps.
        • mu2
          • Oct 2009
          • 217
          I had a similar issue with a different Samsung.
          The model was LNT4061FX/XAA
          It had a capacitor problem and when I upgraded the firmware to the most current version on the website - I got a picture similar to yours.
          The fix was to go into the service menu.
          In my case it was Option byte - lvds tx fmt
          Change to VESA (from JEIDA)
          LVDS tx - should be 8 bit.
          Can't guarantee that it will work for you but it's worth taking a look at the current setting.
          Mike
          • tvtimmy
            • Mar 2015
            • 1160
            • usa
            I just changed another t con in that same model. I got it off e bay from china for $43. Changed the ldvs setting from JEIDA to PDP and this one works great now too.
              09-07-2024, 05:50 AM
            • TR103
              by TR103
              - it keeps rebooting
              01-22-2025, 04:12 PM
            • JJAAMM
              by JJAAMM
              Problem
              07-06-2023, 06:01 AM
            • Mgiffune
              by Mgiffune
              06-09-2024, 10:28 AM
            • Dodgethis
              Samsung QN75Q6DRA, No Picture, Has BL, and Sound
              by Dodgethis
              Hello all,
              This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
              09-11-2024, 07:39 AM
