help sony kdl-52v5100 dead!!!
  • mattstolte
    • Dec 2013
    • 612
    • usa
    so I got this set its dead guy said when we had storm it went out. it has no lit led outside for power or no blink code so 1st think I did was check stand by voltage its suppose to have 3.3v well its less then 1v so I get new power supply and same thing? im not to good with these sonys but still no standby it should be bad power supply right? is it possible the power supply I received was bad? just don't make sense that they both have under 1v, so im thinking its something else?
  • mmartell
    • Oct 2013
    • 3189
    Re: help sony kdl-52v5100 dead!!!
    Unplug the main board from the supply then check what your standby voltage is.
    • CapLeaker
      Leaking Member
      • 8219
      I think the main board is dragging the PSU down.
      • mmartell
        • Oct 2013
        • 3189
        Exactly
        • mattstolte
          • Dec 2013
          • 612
          • usa
          i have unplugged the main and same thing
          • CapLeaker
            Leaking Member
            • 8219
            unlplug everything from the PSU and just plug into the outlet. See what happens.
            • mattstolte
              • Dec 2013
              • 612
              • usa
              Samething
              • mattstolte
                • Dec 2013
                • 612
                • usa
                actually no voltage. im not familar with working on these sonys but no voltage is present when everything unplugged, then when i plug main it goes to about half a volt
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  I has a set recently for repair which was dead. No power up light, no blinking of front led.
                  The 5V standby voltage was not present. When scoping it, I found that on initial switch on 350V to a transformer primary feeding a SMPS IC came up which provided a 5V pulse on the secondary of the transformer. This 5V output was also coupled to the input of an opto-isolator the output of which was connected back to the SMPS IC that took it out of standby.
                  The opto wasn't working and replacing it repaired the power supply.
                  Just a thought?
                  • CapLeaker
                    Leaking Member
                    • 8219
                    I guess we need hi res pictures from the PSU and the connector area so we can see the pinout.
                    • mattstolte
                      • Dec 2013
                      • 612
                      • usa
                      Originally posted by dick_barton
                      hi,
                      i has a set recently for repair which was dead. No power up light, no blinking of front led.
                      The 5v standby voltage was not present. When scoping it, i found that on initial switch on 350v to a transformer primary feeding a smps ic came up which provided a 5v pulse on the secondary of the transformer. This 5v output was also coupled to the input of an opto-isolator the output of which was connected back to the smps ic that took it out of standby.
                      Just a thought?
                      i dont know what the opto is can you please send me better detail thanks. I even changed power supply from a used one and same thing...
                      • Andreas_de
                        Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                        by Andreas_de
                        Hello!
                        i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                        Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                        Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                        04-12-2025, 10:38 AM
                        by sam_sam_sam
                        03-31-2024, 02:12 PM
                      • kevin_allein
                        Samsung QE 75 Q 7 FGMTZG Power Supply dead
                        by kevin_allein
                        Hi, have this Samsung QE 75 Q 7 FGMTZG TV with no function. First analysis shows the power supply board is dead and fuse blown. Power Supply has the number BN94-11439A. I did short circuit test transistor and diodes and those do not appear to have shorts. I must admit I did not look at every single data sheet.
                        In the TV was some black dust residue, so probably one of the electrolytic caps blew, but they do not show short either.
                        Does anyone have schematics for that board ?
                        Any good tip, what could be the issue ?
                        02-27-2025, 12:15 PM
                      • KYBOSH
                        Eufy Floodlight Cam 2 Pro Dead. Power Supply issue...
                        by KYBOSH
                        I have a floodlight-security camera that recently died on me.
                        its hardwired to 115v po115v outlet. One evening it simply died. After some troubleshooting (ensuring it had power and ensuring the electronics were actually functional by supplying 5v via usb port) i realized the power supply must be the issue. The supply was noticably warm to the touch even though it was not powering anything.
                        Trying to understand what i was up against i went looking for others with similar issues and anyone who might have attempted a repair. While a few ppl have had the...
                        07-01-2024, 06:54 AM
