samsung un46eh5000fxzc
  • Louis82
    • Feb 2012
    • 240
    Re: samsung un46eh5000fxzc
    UPDATE: Found 2 defective LEDs. Replaced those 2 only and tv it's been playing fine all day for 2 days already. Used LED's from a scrap 50" tv.
      Thanks for the follow-up.
      So you did not try the LEDs that you ordered from China?
      BTW, make sure to turn down the backlghts level to as low as possible in the on screen user setup.
      • Louis82
        • Feb 2012
        • 240
        Hi Budm. I did try them but they were not a perfect fit. They got to be inverted to work and since I don't know much about it, I didn't want to take the chance. Disasembling the tv multiple times is a pain and I'm also afraid of breaking the screen.
        So I used the 50" samsung tv LED and it worked! (UN50EHXX)
          OK, thanks for the info.
          • Louis82
            • Feb 2012
            • 240
            UPDATE: Unit came back grrrrr. 3 more burned LEDs. Different locations. Gave up. A lot of them they look brown and I can't keep risking to break the screen. Game Over.
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8177
              Did you set the backlights lower?
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
                09-07-2024, 05:50 AM
              • cheeky2
                Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                by cheeky2
                This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                06-15-2025, 05:12 AM
                03-31-2024, 02:12 PM
              • jchang
                Samsung UN70NU6900F no picture and no sound
                by jchang
                Hi all
                I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                Symptom:
                No picture no sound.
                When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                No sound at all.
                What I tried:
                1. I tried unplugging the left or right ribbon...
                01-09-2023, 06:28 PM
