Sharp LC52LE810UN Startup error
  • argonrepublic
    • Oct 2012
    • 9
    I have done a bit of homework on this. The strange thing here is that If start TV in service mode, it is fine, works great. Only after unplugging, does it error on startup. Please help!
  • johnboy1313
    • Nov 2012
    • 1959
    Re: Sharp LC52LE810UN Startup error
    What code is flashing?
    • argonrepublic
      • Oct 2012
      • 9
      Flashing short, long, short, long.
      How do I enter service mode?
      • Superbee_dad
        Sharp 80” long short flash backlight error - Help
        by Superbee_dad
        Hello Sharp TV experts
        Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
        > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
        > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
        01-24-2025, 11:51 PM
      • Sus256
        HISENSE 65E7KQ PRO - no boot
        by Sus256
        Hi all!
        HISENSE 65E7KQ PRO
        RSAG7.820.13512 - chassis
        MT9618BAATAB - cpu
        RSAG7.820.12059 - power
        HD650Y3U77 - panel
        KLM8G1GETF - emmc
        The TV does not turn on, the standby indicator is on. All voltages are present.
        Emms is dead. Not readable, not detected.
        Replaced emmc.
        But with another dump there is no launch
        Terminal log
        UART
        AC_ON
        RPMB key is not yet programmed
        HASH1_VERSION=0x00000000 64bit
        E-B
        FDE enabled
        layout pattern onebin by SAR7,0...
        06-01-2025, 02:11 AM
      • Eric D.
        Sharp LC-60LE810UN Lamp error
        by Eric D.
        Hello everyone!
        I just acquired a Sharp Aquos for free.
        When I plug it in, it will try to power on, but it fails.
        The "error code" is 1 long flash, then 1 short flash, which suggests it is a lamp error code, according to the manuals.
        I did a bit of research and did what I found could be the possible issues;
        I removed the back panel, checked for continuity on both fuses where the power cable connects, and I get somewhere around 0.05. That should be good.
        I also tested the leads going into the psu board from the wall connector; I get 120V.
        I disconnected...
        01-18-2025, 05:14 PM
      • michalk3777@gmail.com
        Sharp Hisense - LC-65N7004U Error codes
        by michalk3777@gmail.com
        Hello, looking for a list of error codes for this TV. made in 2020, its manufactured by Hisense under Sharp brand. No clicks, black screen, no sound, power light is on solid. When I press power, it blinks 5 normal blinks and 1 short. and nothing happens.
        Anybody has a list of error codes that might apply to this TV? I have not opened it yet.
        Regards,...
        12-15-2024, 09:20 PM
      • sushilachuthan
        APC UPS error P13
        by sushilachuthan
        one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
        the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
        The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
        We replaced the SCR with new device,, but the device is not power on as expected.
        Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
        09-26-2025, 09:00 AM
