Samsung LN40E550
    Re: Samsung LN40E550
    Originally posted by stonoguy
    Please enlighten me on this...why would the outside connections (2) still read ~.1 ohms with the Dual rectifier removed from the circuit? I wish I had a correct schematic...this would be so much easier......there are some components on the schematic & on the board that I have, in which I am not familiar.
    You can see that the two outside legs copper pads are directly connected together.
      what is this suppose to represent??.....A transformer? ....Just trying to get a better understanding on some of the unfamilair items on this schematic. Sorry if I'm being a PITA! Please bear with me as it has been a few years since I was expised to these 'new fangled' items on a scematic.
      TM801S is a transformer with many windings.
      • stonoguy
        • Jan 2012
        • 65
        Would it be OK to plug the set to the AC, apply 120 V and see if the 5.3 vdc standby is present?.....
          Yes. You can run the power supply board by itself without having any other board connected to it, the STBY is an always ON power supply.
          • stonoguy
            • Jan 2012
            • 65
            OK..before I power up, I did some checking and found that the 2 rectifiers that were highlighted in previous pix, have an ohms reading of .3 (reference...cold ground) on the 2 outside connectors.....you said, those 2 are connected to each other. Are these 2 rectifiers going to a transformer that connects to ground after the windings? Do you have any idea where I can get a correct schematic for this board? It's very frustrating not knowing if measurements are correct.
            • stonoguy
              • Jan 2012
              • 65
              I powered up that PS board and measured 5.2 DCV.......the part I ordered has not arrived yet. The part(s) ID on the schematic I have, do not match the numbers on the components on the board. Confusing.......this is the first time I have run into this. This has been a learning experience....for sure! I have never run into 3 leg rectifiers nor rectifiers mounted on a heat sync. New stuff for me. Thanks for putting up with my ranting. The part that I ordered was not found @ Mouser or DigiKey. I finally found one on Amazon. "I'll be back."
              • stonoguy
                • Jan 2012
                • 65
                BTW.....That 5.2 dcv was the stand-by voltage.......
                  So you do have the STBY 5.2V with the main board connected or not connected to the power supply board?
                  • stonoguy
                    • Jan 2012
                    • 65
                    No other boards are connected to the power supply board. I still haven't received the replacement part, so I was hesitant to connect the main board.
                    • stonoguy
                      • Jan 2012
                      • 65
                      https://www.badcaps.net/forum/images/editor/attach.gifRe: Samsung LN40E550
                      I connected the main board to the power supply board and got these results:
                      POWER SUPPLY PCB
                      Plug CN 802
                      Pin 13 (B5V) 0 V
                      Pin 12 (A5V/stand-by) 5.2 V
                      Plug on Main PCB going to IR:
                      3.3 V going to IR from (I assume)
                      Pin 3 3.3v
                        So the 5.2VSTBY is fine when the main board is connected to the power supply board, but you do not have the switched B5V which is turned on when the power supply board gets the PS-ON signal from the main board.
                        You need to locate and check the PS-ON pin on the connector of the power supply board to see if it is present or not.
                        • stonoguy
                          • Jan 2012
                          • 65
                          Please explain about PS-ON.......is this a dc voltage?
                          • stonoguy
                            • Jan 2012
                            • 65
                            I have found the PS-ON connection on the CN802...Pin 14.
                            3.48 v.
                              Oh, I forgot that you had found shorted MOSFET that you are waiting for the replacement. So right now the STBY power supply is working and you do have PS-ON.
                              You might as well check the DCV between the two legs of the main filter cap in the primary side to see if you do have the 400VDC booted Voltage between the two legs of the main filter cap or not. Be careful since you are working in the deadly primary side of the circuit.
                              • stonoguy
                                • Jan 2012
                                • 65
                                Nope.....~164.8 Vdc (Hot ground)......the set is not operating, so this would be the voltage in the stand-by mode?
                                  It must be partially working otherwise you will not have the PS-ON Voltage which is generated by the main board when power switch is activated, when the power supply receives that PS-ON signal it will turn on the PFC Voltage booster circuit and other switched power supply sections.
                                  • stonoguy
                                    • Jan 2012
                                    • 65
                                    OK....just waiting on replacement part. Hopefully, I will receive it SOON! I am anxious!
                                    Does the 13v/5.3v feed the audio/video circuits? The original problem was the set would go ON/OFF every 30-35 seconds or so. I didn't get to inspect very much, as the set was dead after turning it off and trying to turn it back ON.......I can't swear to it, but I thought I viewed the backlights being on when the set had no sound/pix. Any thoughts?
                                    • stonoguy
                                      • Jan 2012
                                      • 65
                                      I did some more investigating and found on the embossed graphic (main board) by plug CN202(?), the voltages that are supposed to be on the pins of that connector. 5.3v std-by/5.3v/13v were displayed. When I receive that part, and install it, we'll see!
                                      • stonoguy
                                        • Jan 2012
                                        • 65
                                        I finally received the replacement part and installed it. The set fired up. When I turned the set on/off, I heard the “chimes”. I also heard the broadcast audio. I did not verify if video was present because the set is face down. When I adjusted the set to view the video, the set would not turn on…dead, AGAIN!
                                        Checked the component I had just installed and sure enuff, it was shorted. D to G – 756 ohms, D to S - .4 ohms, G to S - 756 ohms. ??????????????
                                        • CapLeaker
                                          Leaking Member
                                          • 8352
                                          Maybe you got a fake Mosfet, something not right with the gate drive or you have a problem on the 13V rail output. Since all the pins were shorted on the mosfet before, I'd be looking at the gate drive.
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
