Panasonic TC-60PS34 red light flashes 7 times
    Hello all,
    Trouble shooting a Panasonic TC-60PS34 with red light flashing 7 times. First I disconnected the SC20 ribbon cable (information I collected while searching for solutions) and connected the power and got 8 red flashes. From all the research 8 flashes means it needs another SC board, which is on the left side. I did not find trouble shooting solutions for this specific model so I was going by "one size fits all" sort of trouble shooting. I appreciate any input and thanks.
    Re: Panasonic TC-60PS34 red light flashes 7 times
    more than likely yes, but I would isolate the sd/su boards from the sc, removed the Vfg bolts that ground the sd/su to the sc(all of them) then locate the small 2 pin connector SC50 on the SC board, jumper those pins together, have the rest of the Tv connected as normal, then power on and see if still 7 blink.
    if so then Sc is faulty, you then need to check both sd/su for shorts because 7 blink can be Sd/su, Sc or all three could have failed together. Installing a new sc without doing this may result in blowing the SC up again if those buffers are bad
      I concur with tw2005
        Ok thanks for your help. I did how you explained, shorted the two pins and removed all screws grounding the three boards and have 7 blinks. So I guess it is time to get three boards.
          get three or work out how to test the buffers. Can you put up some pics or tell me what version boards are installed in this?
          there will be the main PCB number and then a 2 letter suffix
          interested in the SC,Sd,Su and A boards.
            I just jumped onto encompass and this is what they list. If this is correct then if this was my TV and I intended keeping it for as long as possible I would
            • purchase 2 sc boards at Shopjimmy, at $38 it's a steal and a prudent move because in time we see this eventually the boards run out and it's cheaper than any kit repair or getting it repaired, keep the old core board though,you never know in time it can be valuable
            • purchase 2 sets of SD/SU, again so cheap $24ea, test yours you may only need one but spares can be handy
            • if the a board is available and cheap enough get one
            • SS board too if cheap
            and you will have some backup next time , I have heaps of spares for my 2010 FHD and they're all unavailable or expensive now, I got in while they were still cheap used
            SC = TXNSC1PGUU
            COMPATIBLE WITH
            Manufacturer Model Number Description
            Panasonic TCP60S30 60" PLASMA TV
            Panasonic TC60PS34 60" PLASMA TV
            Panasonic TCP60ST30 60" PLASMA TV
            Panasonic TCP60S30UA 60" PLASMA TV
            Panasonic TCP60ST30UA 60" PLASMA TV
            Panasonic TC60PS34UA 60" PLASMA TV
            Sd = TXNSD1QTUU (TNPA5344AB)
            Panasonic TCP60GT30 60" PLASMA TV
            Panasonic TC60PS34UA 60" PLASMA Tv
            SU = TXNSU1QTUU (TNPA5343AB)
            A = TXN/A3PFUUS (TNPH0914AU)
              Please excuse my delay. Here are some pics, let's see if I can post more than 1 pic.
                so looks like AB is no heatsinks and no revision has them . So that encompass data looks to be out but either would work of course going for the heatsinked version would be preferable. I think I'd clarify with SJ or whoever you choose and specify you want the no revison with heatsinks . there's a few listings on Ebay too some quite cheap
                  Ok I couldn't finish posting info and I can't upload more than one pic at a time. Anyway,
                  Here are all boards perspective numbers letters: SD=5344-TNPA5344, SU=5343-TNPA5343, SC=5399AB-TNPA5399. Hope this helps more. Again thanks for your time.
                    Yeah, I got what I wanted from the 1 pic. Anyway, that's pretty lucky less than $40 for a SC board, the buffers you'll just have to fight your own battle with whoever to try and ensure you get what you want but still worth getting extras and / or testing yours. 50/50 chance they're ok but don't chance fitting a new Sc without being sure they're not shorted
                    Quick test would be to check between the Vfg gnd plate on the buffer and slide the other probe along the face of each ribbon connector and watch for low ohms or shorts or use continuity/diode mode and if you get constant beep then is bad.
                      Here is a pic of all three boards.
                        I got it.
                          SJ has the same buffer boards with heat sinks they look the same to me after comparing them. And what you mean by ribbon connectors are all the brown ones on the left side and/or the three white ones that connect the buffer board to the sc board? I slid the probe along all ribbons on the opposite side of where the ribbons connect after flipping up the brown locking bar a few times and got no beeps. I did the white ones in the opposite side as well just for grins.
