2 long 5 short blinks, No picture sharp aquos lc60le640
  • bryan4203
    • Aug 2015
    • usa
    So I was watching tv and it just shutoff. I have tried forcing boot to no avail. When taking readings from pnl 12v with multimeter it is 7.95 volts, not 12. I also found this http://www.tvtechparts.com/DPS162-KI...rd_p_5140.html I tested leg 2 and it is also around 8 dcv. Ive never fixed a tv and was wondering if Im on the right track. Ive tried disconnecting tcon ribbons also, still same error. Should I just buy a new power board?
  • Superbee_dad
    Sharp 80” long short flash backlight error - Help
    by Superbee_dad
    Hello Sharp TV experts
    Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
    > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
    > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
    01-24-2025, 11:51 PM
  • FlorianP
    Sharp Aquos LC-40LE810E - 2 long, 1 short
    by FlorianP
    First of all I am not native English speaking, so sorry for potential mistakes or misunderstanding.
    I have a basic multimeter and a soldering iron. No electronic pieces for replacement for the moment, but I can buy some.
    I have a Sharp Aquos LC-40LE810E with issue.
    When I turn on my TV with the remote control, I have 2 long flashing on the boomerang symbol, and no image/no sound.
    I saw in the service manual that I need to click on « menu » button of the remote control to have more information.
    --> Error core...
    09-05-2020, 10:02 AM
  • cm0002
    Sharp LC-55N7000U 1 long 5 short blinking, no display
    by cm0002
    I've got a Sharp LC-55N7000U. It has a standbuy LED when plugged in, but powering it on causes it to blink 1 LONG and 5 FAST. Theres no display and no backlight.
    Nothing I checked has that blink pattern for Sharp TVs and there's only one multi-button on the TV itself so that service menu trick involving the input button doesn't work either. Its a post-Hisense buyout TV so that probably makes sense lol
    I've tried disconnecting the panel sides from the TCON alternating sides, but no change in behaviour even when the whole TCON is disconnected,...
    06-19-2023, 06:21 PM
  • Noobwithamultimeter
    Sharp LC60C6400U - 2 long binks, 5 short blinks error code
    by Noobwithamultimeter
    Hi, long time browser - first time poster. I got my hands on a Sharp LC60C6400U and from what I could find on youtube similar models of this set have a 12V power regulator that fails called "KIA378R12PI". So I go ahead and order the part, install it and badda-bing my set worked right away. Only a problem - it failed after about 3 hours. So I re-attempted my solder joints and it was back in business, for a couple of days. Failed again with the same error code. I think to myself no worries I have 4 spares since I bought a 5 pack in case anything went wrong. But now after roasting the solder...
    04-06-2021, 01:31 PM
  • Tom_x
    HP Omen 15-dc0001nh capslock blinks 5 long and 3 short
    by Tom_x
    I have HP Omen 15-dc0001nh (DA0G3DMBCE0 rev: E) with blinking capslock 5 long and 3 short. Fans spin constans speed.
    HP worked for 2 months after i repaired (before damaged by thunder via rj45 port) I removed LAN ic and powered on
    Now with blinking capslock:
    All voltage present on big coils, except +VCCGT (i don't know this need for booting)
    I tried re-flash bios with known firmware- same result (now i don't have spare bios chip to test spi flash failure)
    DDR4 ram is ok, tested on other laptop
    WLAN and SSD removed,...
    07-20-2023, 10:10 PM
