Samsung 50 plasma PN50C550G1FXZA
  • freemancomputer
    • Aug 2015
    • 18
    I have a Samsung PN50C550G1FXZA 50 inch plasma with sound but no picture. There were black lines horizontal lines going across the screen, because of this I replaced the y buffer board. Now there is no picture, I tried putting the old board back in but nothing. There is a green light on the main logic board that flashes once every 5 seconds.
    From what I have been able to find online the flashing indicates that the y board is having problems. My questions that I have is 1)Does it sound like the Y board 2)If so should I replace both the buffer and the y board or just the Y board 3)Is it worth it to replace the parts, are they likely to go bad again?
  • Hamie
    • Apr 2014
    • 1383
    Re: Samsung 50 plasma PN50C550G1FXZA
    The horizontal lines are probably caused by a bad panel.
    • freemancomputer
      • Aug 2015
      • 18
      That's a new one that I will have to look into. Anything I have been able to find online that had to do with black lines on a plasma tv had to do with the y board.
      • Hamie
        • Apr 2014
        • 1383
        How many black lines are we talking about?
        If you have a perfect picture apart form one or two black horizontal lines, then it's usually a panel fault.
        • freemancomputer
          • Aug 2015
          • 18
          There were 2-4 thin black lines.
          • Hamie
            • Apr 2014
            • 1383
            Unplug the buffer board from the y-sus.
            Check the vsc (vscan) voltage, there should be a test point on the y-sus.
            Note: the y-sus shouldn't cause a horizontal black bar so if vsc is perfect and matches the panel sticker then you could repace the buffer.
            • freemancomputer
              • Aug 2015
              • 18
              So the readings started out really high around 400 then went down to 0 after about 30 sec. I have attached some images to make sure I am testing the right area.
              Thank you for you help
              Terry
              https://drive.google.com/file/d/1yxx...ew?usp=sharing
              https://drive.google.com/file/d/1C6T...ew?usp=sharing
              https://drive.google.com/file/d/1jUv...ew?usp=sharing
              • Hamie
                • Apr 2014
                • 1383
                That is high.
                Just to make sure you're testing it properly.
                DC volts, red probe to the test point, black to chassis.
                Looks like you have a faulty y-sus.
                The black lines however are either caused by the panel or the buffer.
                If you're going to continue with the repair and swap out the boards I'd replace both.
                There's a good chance the bad buffer took out the y-sus.
                You can check the buffer board ICs for shorts to be positive.
                • freemancomputer
                  • Aug 2015
                  • 18
                  I thought it was high as well. I'll test the buffer tonight and post findings. I can get the y-sus but the buffer is out of stock everywhere I've looked. I'll order the y-sus but hols off until I can get the buffer.
                  • freemancomputer
                    • Aug 2015
                    • 18
                    The battery's I'm my meter were shot, replaced those but its only a little better. The voltage starts at 199 and over a minute it drops to 0. I attached a video that I loaded to YouTube for reference.
                    Terry
                    https://youtu.be/UOp5tnbw6is
                    • sordids999
                      • May 2013
                      • 2160
                      • uk
                      have you tried test patterns to eliminate the panel ?
                      • freemancomputer
                        • Aug 2015
                        • 18
                        There's no picture right now, can that be done with no picture?
                        • Hamie
                          • Apr 2014
                          • 1383
                          Yes although it probably won't make any difference as the voltages are dropping off.
                          • Hamie
                            • Apr 2014
                            • 1383
                            On the control board (the one above)
                            See the small black square in the top right hand corner, it has 4 pins numbered 1-4.
                            Connect pins 3 and 4 with a piece of wire, croc clip etc
                            Disconnect the LVDS cable to the main board.
                            If you get test patterns you have a faulty mainboard.
                            • Hamie
                              • Apr 2014
                              • 1383
                              Earlier When you checked the vsc voltages was the buffer connected?
                              • freemancomputer
                                • Aug 2015
                                • 18
                                no it was not
                                • freemancomputer
                                  • Aug 2015
                                  • 18
                                  That test didn't change anything
                                  • Hamie
                                    • Apr 2014
                                    • 1383
                                    Ok what's the vsc voltage with the buffer connected?
                                    • freemancomputer
                                      • Aug 2015
                                      • 18
                                      The voltage was the same starting at 199 then dropping off.
                                      • Hamie
                                        • Apr 2014
                                        • 1383
                                        What's the ve voltage on the xmain (zsus)
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • ohren
                                          Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                                          by ohren
                                          I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                                          I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                                          The models launched in 2018 and 2019 respectively....
                                          09-08-2023, 05:24 PM
                                        • fredtred
                                          Physically bending the T-Con board creates horizontal dotted lines on OLED55CXPUA
                                          by fredtred
                                          Hello!
                                          I have been trying to solve this issue the past 12 months to no avail. I have been a lurker here during that time but finally decided to post my problem and see if anybody knows a solution.
                                          Problem
                                          My tv (OLED55CXPUA) has an issue where it displays horizonal lines of dotted artifacts.
                                          (See Attachment 1)
                                          Self Diagnosing
                                          After a very long troubleshooting period I traced the issue to the T-Con board. If I gently flexed/bend the board I could make the display go from GOOD to BAD and vice versa. I have ruled out the connectors/wires...
                                          10-29-2023, 01:09 PM
                                        • C152Heavy
                                          Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                                          by C152Heavy
                                          Summary for TL-DR readers:
                                          • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                                          • Have obtained Samsung schematic & service documents - Can upload if helpful.
                                          • Have read ALL applicable threads
                                          • C1818 and CP820 replaced as low hanging fruit
                                          • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                                          • VCC pin (18) of PFC...
                                          01-11-2023, 02:53 PM
