Samsung 50 plasma PN50C550G1FXZA
  • freemancomputer
    • Aug 2015
    • 18
    Re: Samsung 50 plasma PN50C550G1FXZA
    Starts out at about 90 then settled down at 5
    • Hamie
      • Apr 2014
      • 1383
      Ok so vsc and ve are matching the panel sticker?
      You'll need to jump on the power supply without the mainboard attached.
      PS-On jump with ground.
      Vs-on jump with 5vstby
      Disconnect the main board. And put the test pattern short back in place.
      • freemancomputer
        • Aug 2015
        • 18
        It might be because I just woke up but I did not follow that at all.
        • Hamie
          • Apr 2014
          • 1383
          to completely rule out the main av board we need the power supply to start without the mainboard connected.
          You need to trick the power supply into thinking the mainboard is sending the signals to start up.
          So look at the legend table that connects the power supply to the mainboard. It will be near the wire (upload a picture of the power supply connector to the main board if you're not sure)
          Then with a piece of wire connect ps-on to ground, and vs on to 5v standby.
          The power supply will now turn on without the mainboard.
          You can jump it on like this:
          (Obviously the picture above is not representative of the holes you'll need to jump)
          • Hamie
            • Apr 2014
            • 1383
            Can you also upload a photo of your panel sticker.
            • freemancomputer
              • Aug 2015
              • 18
              Thats why I was confused I dont see a 5v standby.
              https://drive.google.com/file/d/14jM...ew?usp=sharing
              I think this is the sticker that your asking for
              https://drive.google.com/file/d/1zgU...ew?usp=sharing
              • bwilliams60
                • Aug 2014
                • 109
                Hamie,
                Can you help out the Dead 42" Samsung plasma as well or are we as far as we can go. I can follow this thread, seems similar. Let me know please.
                • Hamie
                  • Apr 2014
                  • 1383
                  It's the connector next to it I think,
                  I can't see the table as the wires are covering it .
                  • Hamie
                    • Apr 2014
                    • 1383
                    Originally posted by bwilliams60
                    Hamie,
                    Did you manage to replace the resistor?
                    If so bump your thread back up.
                    • freemancomputer
                      • Aug 2015
                      • 18
                      Here are 2 more pics to make sure Im looking at the right wires. The pic i sent you before goes to the main board and the one next do it goes to the AV.
                      https://drive.google.com/file/d/13x1...ew?usp=sharing
                      https://drive.google.com/file/d/1dfY...ew?usp=sharing
                      • bwilliams60
                        • Aug 2014
                        • 109
                        I bumped it back up three days ago and sent you a PM. The resistor has been replaced.
                        • Hamie
                          • Apr 2014
                          • 1383
                          Ok didn't notice that.
                          Bump it again please.
                          • freemancomputer
                            • Aug 2015
                            • 18
                            I was trying to figure the wiring out and came across this.
                            auto download PDF
                            Whats throwing me off is both of the cables have a ps-on. I dont want to just start jumping wires.
                            • rccrasher65
                              • Mar 2014
                              • 625
                              Gentleman, sorry to say but, this tv model is notorious for bad panels. I had the same exact model with black horizontal lines, bad panel. mine started out the same way. with one, then two black lines, in a day or so whole panel had lines. If you have lines already don't waiste your time or money. Tom helped me get mine running and picture started out with one black line, then continued from there. I also have most of the boards left. Sorry for the bad news.
                              • rccrasher65
                                • Mar 2014
                                • 625
                                The horizontal lines are probably caused by a bad panel.
                                Hamie, In this perticular model you are absolutely correct, bad panel.
                                • freemancomputer
                                  • Aug 2015
                                  • 18
                                  But does a bad screen cause the voltage drop that I'm seeing?
                                  • rccrasher65
                                    • Mar 2014
                                    • 625
                                    Your fault could have been caused by any one of the boards in the tv, or the panel itself. Mine ended up being a bad main logic board. fuse went on the board. I replaced fuse and she fired up with one black line, so we thought buffer boards replaced them, no change. Lines just continued to get worse more and more the longer it ran. The picture and sound were good but full of lines.End result faulty panel. You can find a million boards for this set, for a reason. I have most of mine. All replacement boards were checked befor placing in tv. the ribbon cables were never touched, so no misalignment there. befor purchasing buffer boards, I did go through the ribbon cables just in case, they got misaligned, no change. My replacement boards were purchased from a member here who checks and double checks any boards he has for sale, plus I rechecked them befor placement. You can check out my thread, pictures included.
                                    • freemancomputer
                                      • Aug 2015
                                      • 18
                                      I was hoping it's not the screen, don't have the cash for a new TV right now. But if it's bad its bad, might see if I can part some of it out.
                                      • rccrasher65
                                        • Mar 2014
                                        • 625
                                        part it out. you might be able to find another tv cheap to fix. Sorry for bad news, just didn't want to see you put any money into it for nothing.
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • ohren
                                          Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                                          by ohren
                                          I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                                          I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                                          The models launched in 2018 and 2019 respectively....
                                          09-08-2023, 05:24 PM
                                        • fredtred
                                          Physically bending the T-Con board creates horizontal dotted lines on OLED55CXPUA
                                          by fredtred
                                          Hello!
                                          I have been trying to solve this issue the past 12 months to no avail. I have been a lurker here during that time but finally decided to post my problem and see if anybody knows a solution.
                                          Problem
                                          My tv (OLED55CXPUA) has an issue where it displays horizonal lines of dotted artifacts.
                                          (See Attachment 1)
                                          Self Diagnosing
                                          After a very long troubleshooting period I traced the issue to the T-Con board. If I gently flexed/bend the board I could make the display go from GOOD to BAD and vice versa. I have ruled out the connectors/wires...
                                          10-29-2023, 01:09 PM
                                        • C152Heavy
                                          Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                                          by C152Heavy
                                          Summary for TL-DR readers:
                                          • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                                          • Have obtained Samsung schematic & service documents - Can upload if helpful.
                                          • Have read ALL applicable threads
                                          • C1818 and CP820 replaced as low hanging fruit
                                          • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                                          • VCC pin (18) of PFC...
                                          01-11-2023, 02:53 PM
