Sharp LC60LE650 Red streaking
  • hiroo
    • May 2015
    • 14
    Friend gave me a Sharp LC60LE650 LED LCD HDTV with weird red streaking in the image.
    Any clues on what the problem is? TCON board? Bad caps?
  • Hamie
    • Apr 2014
    • 1383
    Re: Sharp LC60LE650 Red streaking
    Looks like a bad panel I'm afraid
    • hiroo
      • May 2015
      • 14
      Are there other types of images to test to more conclusively indicate the problem? The unit is only 1 year old.
      • Hamie
        • Apr 2014
        • 1383
        You might be able to get test patterns in the service menu.
        But I'm pretty confident the panel is bad.
        Unsure if this will get you into the service menu.
        http://www.riddledtv.com/forums/shar...odes-t293.html
        • hiroo
          • May 2015
          • 14
          Here is a video of the problem. Weirder than I thought. It has this slow motion stutter step to the moving image. Everything seems to take place slowly when moving around menus too.
          https://www.youtube.com/watch?v=XGfSS5POjQ0
          • hiroo
            • May 2015
            • 14
            Another video:
            https://youtu.be/FHsJVU4ETe8
            Seems like it might be a processing problem? Both videos are from the internal OTA ATSC tuner. I didn't get a chance to try HDMI input yet.
            • hiroo
              • May 2015
              • 14
              here a video showing a fix for a similar problem but they don't explain anything about what/why they are connecting the wire so that the fix can be extrapolated to other models:
              https://www.youtube.com/watch?v=9UrTVEC5LkA
              • advant
                by advant
                02-03-2020, 12:25 AM
              • sefoster
                Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                by sefoster
                I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                11-20-2022, 09:29 AM
              • gavenb
                Sharp LC-80LE661U 80 inch
                by gavenb
                Hi folks!
                I have a LC-80LE661U that had some interesting issues.
                Initially, it would come on and show the sharp logo and would show normal static before shutting off.
                I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
                11-12-2023, 02:05 PM
              • SONY_E-WASTER
                Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
                by SONY_E-WASTER
                Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
                The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
                then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
                does...
                12-26-2021, 05:46 PM
              • Loki_Fido
                (Weird) BIOS info for HP Pavilion Aero 13-be1021AU
                by Loki_Fido
                Hi folks,
                This HP Pavilion Aero 13-be1021AU came to me for a repair. And it seems to have a weird BIOS chip. (Pic attached)
                I asked my CH341A to read it and doesn't even know what to do with this. We are both very confused.
                BIOS - XMC 25RU128CH10 (1.8v)
                What the heck is this? I looked all over the MB. This is the only bios.
                When I asked the NeoProgrammer to detect it, it just pops up an empty screen, and asked me to enter the bios number. And when I did, it doesn't do anything. NeoProgrammer showed me just this SPI ID: 204418. Don't know what...
                03-20-2025, 01:57 AM
