LG 60PK250 No Picture has sound. But sometimes will turn on with picture(rarely)
  • vinceroger69
    • Mar 2012
    • 6714
    Re: LG 60PK250 No Picture has sound. But sometimes will turn on with picture(rarely)
    maybe not as the resitors are ok wait for hamie to see youre above picture as he may get you to run some voltage tests next.
    • Hamie
      • Apr 2014
      • 1383
      No the FET is probably OK.
      I'm not convinced yet you have a problem with the power supply.
      Disconnect everything from the power supply. Remove the wire that connects the power supply to mainboard (remove the wire from the mainboard end)
      And with a piece of wire connect stby and RL-On together. Like the photo below.
      Plug in the tv, the power supply should now turn on and give vs and va voltages.
      Does it?
      • Hamie
        • Apr 2014
        • 1383
        Pic
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          How can it be a Oc or Sc failed part if its intermittent though ? Maybe tun the test patterns ?
          • marty_cam
            • May 2014
            • 19
            • Ireland
            Does it?
            Thanks Hamie.. I'll Try that now. It's a beast of a thing to lift onto this service mount I've set up ..lol
            I'll let you know results bud!
            Thanks again
            • vinceroger69
              • Mar 2012
              • 6714
              #26
              ive just read post 1 again i had missed the part he had said with the new ysus the set turned on once.
              • marty_cam
                • May 2014
                • 19
                • Ireland
                #27
                Same results.... only now, problem seems to have gotten worse. I'm getting much the same results on Y-SUS out... No voltages at all, when trying using the mainboard to power on, and also using the stby and RL-On shorted....
                The strange bit is I'm getting sound on the HDMI in still..... btw, not sure if this is relevant, when set powers up, the power LED goes from red to UNLIT.... although it responds with a red light when front panel button press (e.g. vol up, down etc.)
                Has anyone else had this with this particular set?
                Cheers Hamie!
                • marty_cam
                  • May 2014
                  • 19
                  • Ireland
                  #28
                  Right....
                  After thorough testing.... All voltages are OK except for the ones marked VS.. It seems to go from 195 to -1....
                  posted pic.... ignore last post... my daughter was bothering me and I was getting extremely confused (she talks at 3x speed)...
                  does this help anyone, help me?
                  regards.
                  • Abe1977
                    • Oct 2017
                    • 3
                    • italy
                    #29
                    i have a big problem with my 60PK250
                    The firmware upgrade did not work and now the TV no longer works.
                    I tried to force a firmware through serial port (from usb can not be that nothing goes) ... but I get a "Bad magic number" error.
                    On some forums I have read about people who have solved by installing via serial port a full backup of another equal TV (which is downloaded by serial).
                    Does anyone who has a tv like mine would be so kind to link a backup?
                    Thanks in advance for your help.
                    • Abe1977
                      • Oct 2017
                      • 3
                      • italy
                      #30
                      Hello guys,
                      nobody knows how to help me?
                      • Abe1977
                        • Oct 2017
                        • 3
                        • italy
                        #31
                        Hi, no one can help me?
                        The service center says that the main one needs to be replaced and it needs 240 euro
                        • tw2005
                          • Oct 2011
                          • 6458
                          Over here the 50" board can run the 60" model too. Got any images of your board? Do yo know which chip this data is stored on? Can you order just the chip pre-loaded from LG which I know you can for Panasonics?
                          • TR103
                            by TR103
                            - it keeps rebooting
                            01-22-2025, 04:12 PM
                          • Mgiffune
                            by Mgiffune
                            06-09-2024, 10:28 AM
                          • Ierwin
                            by Ierwin
                            05-13-2025, 03:31 PM
                          • jchang
                            Samsung UN70NU6900F no picture and no sound
                            by jchang
                            Hi all
                            I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                            Symptom:
                            No picture no sound.
                            When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                            No sound at all.
                            What I tried:
                            1. I tried unplugging the left or right ribbon...
                            01-09-2023, 06:28 PM
                          • Dodgethis
                            Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                            by Dodgethis
                            Hello all,
                            This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                            09-11-2024, 07:39 AM
