Lg 55ld650
  • husky601
    • Apr 2015
    • 36
    Lg 55ld650
    I do have a problem with my TV. When i plug the tv the standby light turn on. As soon i press on the power, the chanel or the volume on the standby light flash non stop and nothing happen. On the main board there is a small black buton, i guess it's a reset? If i plug it in and press on the small buton the back light turn on but for 0.1 second then shut down again. Any idea?
  • husky601
    • Apr 2015
    • 36
    Re: Lg 55ld650
    I did put the motherboard in the oven then re instal it in the tv and it did work but shut down every few minutes then turn on again by it self. Do anybody has an idea of what it could be?
    • AleMonti
      LG 55EG910V - no power and no standby light
      by AleMonti
      I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
      I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
      The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
      After checking the basics I did the following:
      • I measured all voltages and as expected the only active supply is the 3.5V standby. It
      11-04-2024, 05:02 PM
    • jasonbay13
      Philips 37HFL5682L/F7 no standby light, incomplete service manual?
      by jasonbay13
      picked up a tv and when the power is plugged, the standby light flashes real quick then goes off. of 3.3, 12, 24v is all there but i couldnt find any 5v on the back-end board. ON/OFF is low, which it seems is what turns on the backlight so i removed the wire at the back-end board and put a 10k resistor to the 3.3v, which when plugged in brings on the backlight for a split second and also a blue light "LED1" on the inverter board, which goes off after a short time.
      am i missing something to bring on the backlight or is the inverter/ccfl gone bad? would that cause the inverter board...
      12-01-2023, 09:55 PM
    • Nicktronic
      Samsung UN70NU6070F Standby Light flashes twice
      by Nicktronic
      Hey Everyone,
      So I've got this Samsung and the reported issue is that when powered on the backlight comes on, but no picture, no sound, it will flicker, the standby light will flash red twice and repeat the whole process...each loop lasts about 15 seconds.
      I've googled the issue and understand it is likely a panel/driver board issue, but was hoping the "tape method" could be successful. Before I did that though, I disconnected the left LVDS cable and powered the TV on. This time I got sound, no picture and the two blink standby light stopped. Did the same...
      03-27-2023, 07:01 PM
    • Woodsworth
      PS3 CECHC03 60GB YLOD Troubleshooting
      by Woodsworth
      I have a post on psx-place for this but thought I'd try here as well in case anyone has experience or the schematics or any kind of help. Here's the original post from psx-place:
      START
      Hi, so I bought a YLOD Fat PS3 as I wanted a repair project and thought it would be a good way to get experience. I was able to solder to the RX, TX and Diag pads on the COK-002 motherboard and was able to get external access and retrieved the codes. I haven't powered it on beforehand so these should be the last ones. I did try to get internal access immediately after but kept getting scopen response...
      03-19-2024, 07:58 AM
    • ctroxtell
      Samsung UN70tu7000wxza no standby light, do I have bad capacitors?
      by ctroxtell
      I picked up a 70" Samsung UN70TU7000WXZA. The original owner said they were watching it when the power surged and knocked it out. I pulled the back off the TV and disconnected the main board from the power board, and the LED backlight came on, which I was told meant the power board was good. When everything is plugged in the standby light will not come on, looking at the main board BN94-17775A with a thermal imaging gun I can see one of the chips labeled 3202 is 251 degrees F just sitting idle. I found a replacement board, BN94-16115X; this board has the same symptoms, except it is a different...
      01-03-2025, 08:57 PM
