42pfl7432d
  • RAMSELECTRONICS
    ATARI boy
    • Jul 2015
    • 48
    42pfl7432d
    I have a TV with 42PFL7432D/37
    I replaced BOTH inverter boards Master and Slave.
    I replaced the power supply.
    Issue is when it power on and backlight does turn on and 1 sec then off!.
    Any idea?
    Re: 42pfl7432d
    It may have bad lamps, bad lamp's connection, the BL-ON drops out, the PWM_DIM drops out, the 24VDC power supply drops out, etc.
    You need to check the all those Voltages to see what disappears when the backlights drop out.
    • RAMSELECTRONICS
      ATARI boy
      • Jul 2015
      • 48
      Re: 42pfl7432d
      Okay, will check it out.. thanks
      • RAMSELECTRONICS
        ATARI boy
        • Jul 2015
        • 48
        Re: 42pfl7432d
        Forgot to leave message here.. I got replaced lamps and worked. thanks!
        END OF LINE.
