Panasonic 50" Plasma A Board
  • Larry129
    • Jul 2015
    • 5
    • usa
    Thanks to help from posts and attachments on this site, I just got a replacement A board TNPH06921A for my TH-50PX75U and voila I have a picture!!!
    However it only fills part of the screen, about 41" diagonally to be precise.
    I think this board is also used in 42" plasma tv TH-42PX75U. What do I need to do get the full picture?
    ps. The board p/n is exact match for what came out of my set.
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic 50" Plasma A Board
    what revision did you get? TNPH0692 will be the PCB , 1A is not relevant but there should be a revision suffix usually 2 letters which is important to match the correct board for the size of the panel. Does sound like you got a board for a different model.
    Have a look here for the different versions that apply t each panel variant
    http://www.shopjimmy.com/catalogsear...lt/?q=TNPH0692
    • Larry129
      • Jul 2015
      • 5
      • usa
      My old PCB was Suffix "AC".
      The new board is "AB". Does this mean the new board is not compatible with my 50" TV or is there a fix?
      • Larry129
        • Jul 2015
        • 5
        • usa
        Where can I get the right board TNPH0692 Suffic AC.
        Also, what to do with TNPH0692, Suffix AB?
        • tw2005
          • Oct 2011
          • 6458
          well if you're stuck with the board and can't return or locate AC the only suggestion I have would involve eeprom swapping. What you'd have to do is get the serv manual for both then compare the eeprom numbers used in each. find the ones that differ and swap them from you're old board to the new one and hope that sorts it. It should as the only difference is the data loaded on these. You won't have to do all but I'd expect 1 -2 chips will be different without looking at it.
          • johnboy1313
            • Nov 2012
            • 1959
            Unfortunately, the only fix is the correct suffix.
            You'll have to keep looking. Ebay, ShopJimmy, Google. You can try to send the suffix AB board back to where you got it.
            • tw2005
              • Oct 2011
              • 6458
              If it's only A board been changed these are what to compare to the 42
              this is what should be on the Ac version. Find the difference and swap those, the numbers are what are important.
              IC1101 TVRP388S
              IC4500 TVRP387S IC 1 PAVCA
              IC4501 TVRP386S IC
              IC8502 TVRP390S IC 1 PAVCA
              IC8503 TVRP391S IC 1 PAVCA
              IC9001 TVRP208S IC
              IC9007 TVRP211S
              IC9303 TVRP216 IC
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • stecos
                Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                by stecos
                Hi everyone!
                I happened several times, in the search for help from the web, to consult this very interesting forum.
                So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                Having said that I come to the gist of my post on the forum as the title suggests.
                For my passion for technology I'm now collecting several...
                11-28-2022, 11:39 AM
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
                After all of...
                07-13-2024, 08:14 PM
              • canadaboy25
                Panasonic TC-P54VT25 No image. A or D board?
                by canadaboy25
                I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                01-17-2021, 01:06 AM
