ps50b451b2wxxu clicking not turning on
  • Blueeyes
    • Jun 2015
    • 60
    • Uk
    Re: ps50b451b2wxxu clicking not turning on
    Pin
    2=.16
    3=1.6
    4=nothing
    5=1.6
    6=nothing
    Resistors are fine I am a little worried when I flipped board over I found this
    Seems its been soldered badly and few burns any chance its related?
    No shorts found
    • flocko
      • Nov 2012
      • 1121
      Pin 1+2 are the Vs this is short (.16 ohm ?) But please check again, By the looks this board has been worked on before in the photo that's just were it has been soldered, the parts to check are Q804/5/8/9/ Q810/11 and there gate resistors and ICs U800/812 these are the parts that would be shorted or blown and I would recommend replacing . I have now looked and I have a board should you need it.
      • Blueeyes
        • Jun 2015
        • 60
        • Uk
        II'll send picture of my dmm its a cheap one as haven't got round to buying decent one but show 1+2 open and low ohms yeah I'd say it has looks like one or two places board is actually missing solder point on q808 q811 so would I check these the same way as normal resistors? I'll upload picture of missing solder joints and how much would you want for the board?
        • flocko
          • Nov 2012
          • 1121
          That would have to be one of the worst jobs I have seen and believe me I have seen some, well the problem you have is that these are some of the parts I have listed so it looks to have badly repaired in the past, my money would be on having to replace all on my list as you have a short on the Vs and bad soldering will not be the problem ,but would be the cause of the blown parts , can you give some background on the set did you buy it faulty or has it been running .
          • Blueeyes
            • Jun 2015
            • 60
            • Uk
            Yeah I picked it up with a with the clicking fault but my first attempt at susing out the problem failed as I thought it was dead capacitors apparently not but looks like its a very bad repair so thinking I'll just get all parts and redo the whole thing , I saw it as a little project I have a few broken set I'm trying to fix
            • Blueeyes
              • Jun 2015
              • 60
              • Uk
              #26
              This is DMM and setting I'm using to test for shorts and the resistors
              • flocko
                • Nov 2012
                • 1121
                #27
                Off hand the parts Kit for this board runs at about £30.00. and can be had from OHM supplies just make sure to get the right kit for your board (rev AA1) as the AA3/AA6 do not use the same parts , it makes it easier to get all the parts from one place , but you can get them any were just use part numbers. But make sure to check SMD gate resistors and change ICs or could blow all your nice new parts and be back to were you started, have fun if you run into a problem just ask ,as I say I have boards here if you want send a P.M
                • Blueeyes
                  • Jun 2015
                  • 60
                  • Uk
                  #28
                  Thanks I'm thinking desoldering the ic might be a little beyond me with my maplin soldering iron
                  • Max075
                    • Oct 2015
                    • 13
                    flocko, I have the same problem. clicking. but soldering is fine.
                    Flocko please can you send the part numbers and location no in that OHM supplies repair kit?
                    Also it says check R5085 / R5086 before buy, but i can't find them on the board?
                    please reply
                    • flocko
                      • Nov 2012
                      • 1121
                      #30
                      Hi Just seen this, so i hope i can help firstly what is the part number on your board ? will need the LJ92-XXXX found on the bottom off your board you will also find there the rev number AAx in the white box, these boards had a few over time with changes to components, so to get the right parts list this is a must have number Flocko
                      • Max075
                        • Oct 2015
                        • 13
                        Hi Flocko, the numbers are;
                        PBA NO: LJ92-01601A
                        REV: AA1
                        PCB NO: LJ41-05905A
                        I found out Q811, Q808, Q810, Q809, Q805, Q804 are shorted and I removed them.
                        Also the diods D820, D802, D819 seems to be shorted but the diods are fine. I checked one of them after removed from the board.
                        I also checked the buffer ICs (IC G with output pins) and they are not shorted
                        • Max075
                          • Oct 2015
                          • 13
                          PBA NO: LJ92-01601A
                          REV: AA1
                          PCB NO: LJ41-05905A
                          found out that dioad short due to R818. Is that normal?
                          Checked following resistors after removed Q811, Q808, Q810, Q809, Q805, Q804
                          R912, R900, R909, R836, R833 = 7 ohm
                          R901 = 116 ohm
                          Also checked U812 and U800 and they are not shorted.
                          • flocko
                            • Nov 2012
                            • 1121
                            #33
                            Have you checked across R904 +R905 For low ohms? if it does show low ohms you have one or two buffer ICs faulty. has your board got the 100k resistor fitted to the back of the board to D823 +Q809 I would go with a kit and change all the parts, but make sure to get the right kit for your rev number, to not change the driver ICs is a mistake and can be a costly one, when the IGBTs go short they can take the drivers with them and in some cases the gate resistors as well. not all ways but if not gone they will be weak and not long for this world. Flocko
                            diodes D802/820/819 will show 2.7ohm short this is normal. Andy does a kit with all 16 parts £21.00 trade +vat and post ohm supplies
                            • Max075
                              • Oct 2015
                              • 13
                              R904 +R905 = 23 K
                              and yes it has the 100k back of the noard
                              If you think need to replace all the parts can you send me the part numbers pls
                              Max
                              • Max075
                                • Oct 2015
                                • 13
                                Flocko is it £29+vat kit?
                                http://www.ohmsupplies.co.uk/epages/...roducts/KIT238
                                or do you have a service manual or or part list pdf for this then i can find out if it is cheaper to buy separate as i do not have a trade account.
                                Also i'm not sure about R901 as it looks burned. small spot on it. gives 116 ohm
                                so its really appreciate if can let me know their values.
                                R901
                                R5091
                                R5082
                                R5089
                                R5083
                                R5025
                                R5024
                                • flocko
                                  • Nov 2012
                                  • 1121
                                  #36
                                  I do not think it will be cheaper to buy in separate parts even with no trade account
                                  parts for Rev AA1 LJ92-01601A
                                  Q809/810 RJH3044
                                  Q808/811 IRFP4332
                                  Q804/815 FGPF50N33
                                  R900/901/909/912/833 6R2 6.2ohm
                                  U800/U813 IRS21956S
                                  U812 ADUM1410 this IC if not changed can over volt the buffer ICs and total the board
                                  good luck it looks a lot of parts, but if you leave any unchanged you can and will blow them again on power up so dont try shortcuts Flocko
                                  • Max075
                                    • Oct 2015
                                    • 13
                                    Q809/810 RJH3044
                                    Q808/811 IRFP4332
                                    Q804/815 FGPF50N33
                                    U800/U813 IRS21956S
                                    Thanks Flocko. yeah i'll check if not i'll buy the kit.
                                    let you know when its done. cheers
                                    • flocko
                                      • Nov 2012
                                      • 1121
                                      #38
                                      I had a look on ebay the kits on there dont cover all the parts,and as for separate parts, I gave up when the list started going over £35.00 and I was still a long way from the end. but with board prices at over £80 still a cheap repair. Flocko
                                      • Max075
                                        • Oct 2015
                                        • 13
                                        Thanks for the info. Just tried to buy kit from OHM suppliers. Its £42 with the tax. So decided to buy parts.
                                        Is it ''6.2 Ohm 6R2 1W 5%'' for the resistors?
                                        one more thing, is there a better place to buy RJH3044? Utsource will take 3weeks
                                        Max
                                        • flocko
                                          • Nov 2012
                                          • 1121
                                          #40
                                          the cheap option is to buy from China and they will take a time to get to you, ebay is an option but will be the high cost one, I think a lot more then Ohm Supplies, but that is your call. The resistors I keep are SMD 1206 1/4w 5% and I use these on this type of job and power boards. I have also given you the wrong part number for U813 it is a IRS21856S this being 14pin the IRS21956S 20pin for U800 Flocko
                                          • LGhost
                                            Samsung ue55d8000yuxxu turning on/off and clicking
                                            by LGhost
                                            Hello everyone! This is my first thread asking for help and I'm new here so please be nice
                                            I'm trying to repair a Samsung TV but not having much success so I've came across this forum and it seemed kinda nice and friendly. The TV is clicking on/off (relay) and I can't seem to put my finger on the issue. The image looks fine (since I can get a glance at the "Smart TV" logo when it boots). But it's just an endless loop of on/off. If I disconnect the mainboard from the PSU it stops doing the "clicking" sound but that's about it. I've already got a used mainboard...
                                            05-22-2023, 05:40 AM
                                          • Sisko
                                            Onkyo-593 No power and now clicking sound
                                            by Sisko
                                            Hi all!!
                                            Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                                            10-03-2025, 02:18 PM
                                          • slimmy182
                                            [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                                            by slimmy182
                                            Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                                            I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                                            Looking on google I found this:...
                                            01-14-2023, 11:55 AM
                                          • beetle1303
                                            Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                            by beetle1303
                                            I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                            On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                            01-13-2025, 08:49 PM
                                          • Sparklingx
                                            HP 450 g1 keeps turning on even tho shutdown/sleep
                                            by Sparklingx
                                            HP 450 g1 keeps turning on even tho I shutdown/sleep . one way to stop the turning on cycle is pressing the power button few seconds thus force powering it off. But then sometimes it does not turn on at all but next day I try again to turn it on and it turns on....
                                            09-23-2024, 12:34 AM
