RCA LED32B30RQD backlight flashing
  • niccapila
    • Apr 2014
    • acuaviva delle fonti
    Re: RCA LED32B30RQD backlight flashing
    ti ringrazio budm, appena possibile staccherò quel filo e farò sapere.di nuovo grazie !
    • Malachi
      • Dec 2015
      • 1077
      • Usa
      Pensi che ti ha capito?
      • jrubasch
        • Aug 2016
        Everyone out there should follow the link from budm. Fixed my RCA for free.
        • opalit
          • Nov 2016
          Taitsui, i solder one 220k resistor in paralel wiht R410 and the result is Q415 blow. After repacement i try the solution from Budm.
          • learnmore
            Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
            by learnmore
            Hello Community!
            CASE DETAILS
            Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
            13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
            Tried inserting firmware on USB and left it in for a few hours, but no change
            03-03-2024, 09:49 AM
          • HTR-Informatique
            Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
            by HTR-Informatique
            YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
            I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
            On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
            I also changed the screen because the PC fell and the screen was broken.
            I changed the battery with a new and original battery.
            I also had corrosion/oxidation on the...
            02-09-2025, 06:51 AM
          • triplefour
            by triplefour
            09-13-2023, 10:43 PM
          • STKR123
            Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
            by STKR123
            As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
            I wonder if re-flashing the BIOS might be of any use here.
            As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
            There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
            11-03-2024, 06:58 AM
          • DanPoka
            by DanPoka
            02-15-2025, 05:05 AM
