Samsung ue19d4003 wont turn on
  • adamp91gvm
    • Jan 2014
    • 706
    Hi guys i have this tv when i unplug the av board the back light comes on and im getting 12.5v going to the av board but when i plug it in i get 13v and the screen goes black
  • adamp91gvm
    • Jan 2014
    • 706
    Re: Samsung ue19d4003 wont turn on
    As shown
      Where is the flat ribbon cable between the integrated T-CON on the LCD panel and the Main board?
      • adamp91gvm
        • Jan 2014
        • 706
        Taken it out as it makes no difference at the moment
          If that cable is removed then there will be no power and signals to run the T-CON board = no pictures on the screen. All you will see is the glowing screen.
          What do you get when that cable is connected? How about the SMD fuse on that T-CON board and the DCV at both ends of the fuse with ref to the chassis?
          • adamp91gvm
            • Jan 2014
            • 706
            I have tried it with the ribbon in still get the same results only put a white screen when av board is not plugged in from power board
              "I have tried it with the ribbon in still get the same results" what does that means? Backligts still on but black screen or backlights are on but gray glowing screen?
              Well, did you check the SMD fuse and the Voltage on the SMD fuse of the T-CON board? Do you also still get backlights when all the cables are back in place?
              • adamp91gvm
                • Jan 2014
                • 706
                The back light comes on only if the power board and just the power board is plugged in if the t con and av board are plygged in to its completely black with no back light the back light is plugged into the power board on these
                  So did you try only AV board connected?
                  Some LCDs go white with no power - others go black. Black is most common. ("Normally Off")
                  • adamp91gvm
                    • Jan 2014
                    • 706
                    No i have tried it with everything connected and the red light flashes a few times then noting
                    • adamp91gvm
                      • Jan 2014
                      • 706
                      Any ideas
                        Originally posted by adamp91gvm
                        Any ideas
                        Well, what happen to this? Did you check the T-CON board?
                        https://www.badcaps.net/forum/showpo...93&postcount=7
                        I have no more suggestion since the request is not replied.
                        • adamp91gvm
                          • Jan 2014
                          • 706
                          There is 5.12 volts going to the t con fuse its like the av board is putting to much power back to the power board and turning it off
                            Main board does not do any thing to put the power back to the power supply, it sends out on command signals to turn on the power supply board and the inverter circuits. If the mainboard is drawing too much power from the power supply then it can cause the power supply to go into shutdown.
                            So one thing is not really clear to me is that IF there is no cable between the main board and the T-CON board, the TV will turn on and stay on and with glowing screen, but if the cable is connected then the TV will turn off?
                            "There is 5.12 volts going to the t con fuse" 5V is the correct Voltage for running the T-CON board, you get that Voltage on both ends of the fuse, right?
                            • adamp91gvm
                              • Jan 2014
                              • 706
                              Yes its right its like when the av board is unplugged the voltage is correct and the back light comes on but when the av board is plugged in its putting much voltage in and turning off
                                OK, lets make it clear, so you are talking about the cable between the MAIN (AV) board and the power supply board, right? If that is the case, the power supply boar is OK because the power supply board has pull-up resistors to simulate PS-ON and BL-ON signals so when the cable is removed, the power supply will come on, same for the inverter circuit (in this case, it is the LED driver circuit) , but when the main board is connected and there are problems on the main board that causes the main board not to send the PS-ON and the BL-ON to the power supply/LED Driver board combo.
                                So you have problem on the main board if that is the symptom.
                                It is 19" so I reaalu do not know how much money you will be willing to spend to get it repair, also you should read the LCD TV basic troubleshooting guide to understand more about what it takes for the TV to function. Ntes: Your TV uses power supply/LED driver combo board, there is no high Voltage inverter circuit.
                                • ohren
                                  by ohren
                                  09-08-2023, 05:24 PM
                                • C152Heavy
                                  by C152Heavy
                                  Summary for TL-DR readers:
                                  • VCC pin (18) of PFC...
                                  01-11-2023, 02:53 PM
                                  09-07-2024, 05:50 AM
                                • Nicktronic
                                  Samsung Power Supply Board BN44-00874F
                                  by Nicktronic
                                  Hey everyone,
                                  This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                                  Anybody...
                                  03-17-2025, 06:20 AM
                                • valvashon
                                  Samsung UN65KU6290F PS board blows fuses
                                  by valvashon
                                  Samsung UN65KU6290F (May 2017); received from local Buy Nothing group. Was listed as "just went dead" and they wanted it gone. I brought it home, didn't notice anything visually wrong with the power supply board, looked up the cost of a new one and that's about as far as it went. Family was tired of tripping on the foot of the set so I decided to dig in and repair or toss.
                                  Can't believe that I didn't check it earlier but I found the main 8 amp fuse blown. Jumped across it with a 10 amp blade style fuse and you can see that it literally exploded inside the second I plugged...
                                  11-27-2023, 01:09 PM
