Re: Seiki SE39UY04 Red standby light, not powering on
I'm not sure if it would disappear before the TV went out because I got it second hand already broken, but I know that it doesn't now. I think the LED should be blue when its working properly also.
If the LED's are bad will I be able to tell with a flashlight test? And if they are bad is it worth trying to fix at all?
So before the TV went out, does the RED LED go off when the power switch is activated? You try both boards but this LED backlights TV do have lots of problem with LEDs going bad.Leave a comment:
I should be able to post some later today, but in the mean time theoretically would replacing the main board AND the power supply board be a safe fix for it if the problem is the main board is not sending power to the backlights and PS-ON?Leave a comment:
We will wait for good clear pictures, you need to check and find out if the main board is sending the PS-ON, THE BL-ON to the power supply board or not.Leave a comment:
So I have a Seiki SE39UY04, and when I plug it into the wall the red standby light on the front comes on, but the power button on the TV doesn't do anything. I have opened up the back and none of the capacitors look bulged or necessarily bad. I really don't want to throw this TV in the garbage but I'm not sure how to fix it. Should I replace the main board or power supply board and hope it works?
I can take pictures of the boards later when I'm at home, but nothing seems burnt out or in the wrong spot on the boards.Tags: None
Hello Everyone!
I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died....06-28-2025, 02:57 PM -
I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
What I already found is that the 12.8V are not an the connector to the main board connector to the power... -
by HughRThis problem description is a lot like https://www.badcaps.net/forum/showth...633#post898633
My Seiki SE39UY04 TV stopped working. I've used it for almost four years as a computer monitor.
Symptom: the status LED is solid red. I think that this means "standby". Pressing "power" on the remote and on the TV doesn't appear to change anything. Normally it would turn blue.
Inside, the only odd thing that l've noticed is a spot on the power supply board looks toasted. This is where one wire from the transformer joins the board.... -
by brithepi2kHi,
I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
cheers...5 Photos -
by AleMontiHi everyone,
I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
After checking the basics I did the following:- I measured all voltages and as expected the only active supply is the 3.5V standby. It
- Loading...
