should i just replace the power supply sanyo dp58d33
  • marlboroa
    • Jul 2012
    • 59
    So far everything i have measured on the hot side of power supply is 44 volts. the standby light does not come on and the set doesnt work.
    its a sanyo dp58d33
  • marlboroa
    • Jul 2012
    • 59
    Re: should i just replace the power supply sanyo dp58d33
    heres some pics
      its a sanyo dp58d33
      When you make Voltage measurement in the primary side of the circuit, you need to use the negative leg of the main filter cap as the primary circuit GND REF. point for your meter, not the chassis.
      So what DCV do you get when you measure between the (+) and (-) legs of those two main filter caps laying on their sides? It should be around 160~170VDC and should jump to >360VDC when the power switch is activated.
      • marlboroa
        • Jul 2012
        • 59
        166 on the cap. nothing changes when the power button is pushed.
          OK, the connectors of the power supply board has label for each pin, so report the DCV reading for each pin and WITH pin names so we can see what Voltages we are missing on which pin.
          http://www.shopjimmy.com/sanyo-1lg4b...pply-unit.htm#
          • marlboroa
            • Jul 2012
            • 59
            using the chassis as ground. i cant get a reading on any of the pins. they are all 00.00
              OK. you do habe 160V to to run the standby power supply, but do have any DCV on any of the pin of the connector, it should have at least standby Voltage to run the main board. You need to get the power supply board working first.
                You should eliminate the possibility of a shorted main board - check that connector with the main board unplugged, too.
                • marlboroa
                  • Jul 2012
                  • 59
                  with main unplugged its
                  bl-adj -1.34 volts
                  ps-on -1.34 volts
                  everything else is 00.00
                  • ecking767
                    • Oct 2009
                    • 492
                    looking at the 1st picture, I see a burn mark near the A/C input.
                    that where I will start. something burn out or you had a surge
                    • marlboroa
                      • Jul 2012
                      • 59
                      It had a lightning hit from what i what i was told. The burn mark they did trying to check the "fuse". cause well its always just a fuse. lol
                        by sam_sam_sam
                        03-31-2024, 02:12 PM
                        by sam_sam_sam
                        07-01-2024, 06:34 AM
                      • shamsudeen
                        Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                        by shamsudeen
                        Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                        I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                        i know that in linear power supply the noise will be very low comparing to SMPS supply....
                        07-19-2025, 07:14 AM
                      • JimBanville
                        Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                        by JimBanville
                        The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                        Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                        I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                        I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                        09-13-2023, 07:21 AM
