Emerson LTDn42v68US comes on then shuts off
  • BestAmusementsFL
    • Jun 2015
    • 10
    typically this would be an issue of the backlight inverter (at least from my own experiences) but i've replace BOTH backlight inverter & AV (Main) Board...just trying to verify that i'm not going crazy and that replacing the power supply SHOULD resolve the issue
    TV turns on (3 flashes of the standby light) i get the input notification box in the upper right then the screen immediately turns off (yes i lose backlight when viewing this process from the rear) i have some pics attached but don't believe they'll be of much assistance
    thanks for any help guys!
    https://onedrive.live.com/redir?resi...nt=photo%2cJPG
  • Agent24
    I see dead caps
    • Oct 2007
    • 4960
    • New Zealand
    Re: Emerson LTDn42v68US comes on then shuts off
    Have you checked if the image is still on the screen when the lights are off? (Shine a torch on it etc)
    Did you check all the supply voltages and see if they are OK and if any change between working and after it shuts off?
    It could be the power supply, eg: bad output capacitors, but also bad lamps could be triggering an inverter shutdown.
    -David VanHorn
    • BestAmusementsFL
      • Jun 2015
      • 10
      Haven't checked with a flash light....will attempt that tonight when I get home....I checked the 16v pinout and that was accurate ~+/-3v
      • BestAmusementsFL
        • Jun 2015
        • 10
        okay so with a flashlight i can see the set is working properly...i can change channels and bring up input menus and so forth...would that lean back towards the inverter backlight board then?
        • Agent24
          I see dead caps
          • Oct 2007
          • 4960
          • New Zealand
          It leans towards the inverter shutting down, which could be due to bad inverter or bad lamps.
          Since you already changed the inverter, it would suggest there may be a bad lamp(s) somewhere. (or bad lamp connector\wiring etc)
          -David VanHorn
            It can be inverter transformers, POWER MOSFETs that drive the Inverter transformers, bad lamp sockets due to corrosion.
            BTW, do not the remove the black plastics that the inverter board sticks into, they are sockets to hold the lamps in place.
            • BestAmusementsFL
              • Jun 2015
              • 10
              and essentially with bad lamps tv = junk/target practice
                Instead of junking it, you can learn about troubleshooting, it will be a good practice on how to take the panel apart to inspect the lamps and see how the panel is put together.
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 4960
                  • New Zealand
                  x2 - also, lamp replacement is not that hard actually. Just go slowly and carefully so you don't damage the panel.
                  -David VanHorn
                  • BestAmusementsFL
                    • Jun 2015
                    • 10
                    anyone have a vendor to grab the lamps from? most of my boards i usually get from shopjimmy or tvpartsinstock but have never had to do a lamp swap...are they solder on or do they plug into a socket?
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 4960
                      • New Zealand
                      I think yours are the plug-in type.
                      I haven't bought any lamps for TVs but I have bought several for LCD monitors. First ones I bought were from CCFL Warehouse but they are expensive.
                      The rest I have bought from Chinese sellers on eBay for much lower cost.
                      You can probably find someone on eBay that sells them. Just look around a bit first, because prices can vary a lot.
                      First of all you have to find out if any are actually bad though.
                      -David VanHorn
                      • huzo
                        HP Omen shuts down when loading OS
                        by huzo
                        The model is 15ec-1061nm
                        Board number is DAG3EDMB8D0​
                        SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
                        10-29-2024, 12:05 AM
                      • chaos-theory
                        Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                        by chaos-theory
                        I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                        Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                        03-14-2025, 05:37 PM
                      • baglaivlad
                        A1706 820-00239 - Works, but sometimes shuts off when the charger is disconnected
                        by baglaivlad
                        Hello everybody!
                        Have in work A1706 820-00239 model. Originally no power, shorted PPBUS_G3H because of corroded C6403, C6404. Some water damage around this components, but nothing major.
                        After replacing this capacitors the laptop came back to work, I reinstalled MacOS and had no issues until I started to test Type-C ports. Sometimes the laptop shuts off immediately when some action with Type-C ports performed (charger disconnected or USB device inserted/disconnected). I checked Type-C port flexes, they are okay, but I cleaned them anyway. I can't see any signs of liquid...
                        11-20-2024, 08:14 AM
                      • samuelphirik
                        Dell inspiron 15 7567 sudden shuts down
                        by samuelphirik
                        Hi. I have a pre-owned Dell Inspiron 15 7567. It worked fine
                        During the first 3 days of owning it until Dell Update software popped a notification about a latest Bios version 1.15.0 and latest Intel ME Software update of which I updated. It rebooted and firstly, Upgraded Bios from version 1.8.1 to 1.15.0 then it started upgrading Intel ME firmware. After that update, my laptop shuts down without notice (Like thermal shutdown)
                        I checked Thermal Paste on the processor and the Graphics Chip and it was dry. Replacing thermal paste has not helped me.
                        Now I've noticed that laptop...
                        07-02-2023, 05:45 AM
                      • fharris1977
                        Emerson LTDN42V68US Red Standby Only
                        by fharris1977
                        Hello. I have an Emerson lcd set and it won't turn on with remote or button board on set. It shows a solid red standby led. I suspected the eeprom(N10) so I replaced it but still same results. I still suspect the main board as the culprit, please correct me if I'm wrong. If it is the main board could antone direct me to repairing it? Thanks in advance....
                        06-23-2020, 07:43 AM
