LG 47LV5500 Strange Problem.
  • Ambrosity
    • Jun 2015
    Last night in the middle of watching a movie, my TV screen all of the sudden started showing weird colors. I tried everything I could apart from taking the dang thing apart to try and fix or diagnose the problem to no avail, so I started to analyze what was happening. The problem is mainly seen in white and black parts of the TV. Black parts are showing green and blue strips of pixels, while white areas are showing strips of pink. I broke down and finally decided to just open the back up on the TV. My first suspect after some research online was a bad T-con. After re-seating several cables I decided to turn on the TV while unplugging each cable to see what changes happen to the screen. When I unplug the left ribbon on the T-Con (in the attached picture, the one I unplugged is the left one that is missing from the picture), the colored strips of pixels go away, and are replaced with vertical black lines exactly two pixels in width and occur every two pixels as well (See attachments). Having seen this, I think I sort of narrowed it down to either being the main board, the T-Con board or the left ribbon connecting the two. I am not positive in how correct I am on this assumption though and would hate to purchase a new board only to have the same issue, so I figured I would come onto this forum for some advice if anyone else has gone through this problem
    NOTE: I am having issues with uploading photos to my post, so here are links to the photos on Imgur:
    Weird colors: http://i.imgur.com/nGTMkOq.jpg
    Weird colors closeup: http://imgur.com/NSCNflR.jpg
    Weird colors on a lighter image: http://imgur.com/HIbC8oj.jpg
    Weird colors on white: http://i.imgur.com/rU7Y0KT.jpg
    T-Con board: http://imgur.com/iK9oOqO.jpg
    Main board: http://i.imgur.com/pVA8ebq.jpg *The red circle on the main board indicates where I unplugged the cable that is connected to the T-Con board.
    *Black vertical lines after unplugging left cable on T-Con board: http://i.imgur.com/NWDzI9a.jpg
    Apologies for having the link to the photos! Any help is appreciated
  • Rdick216
    • Dec 2021
    Re: LG 47LV5500 Strange Problem.
    Did you resolve the issue? What was it? My LG 47LV5500 appears to have the same issue.
    • neilc6
      • Nov 2015
      • 1550
      LV series has BGA issues. Try heating with a hair dryer before plugging in. There are repair services on ebay. Ignore the repair kits since the BGA needs reballing.
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        as above try heating the mainboard with a hair dryer this should prove if its a bga issue no harm in cleaning and re seating the lvds lead too (lead between mainboard and tcon)
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4543
          • Italy - Milan
          faulty bga soldering on tcon.. if it is qfp then reflow it..
          • Hakuu
            by Hakuu
            Hi There,
            More Details
            TV Model - LG OLED77G1PUA
            07-12-2023, 02:37 PM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • advant
            by advant
            02-03-2020, 12:25 AM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • silikon77
            Philips 70PUS7855/12 bad colors when applying the tape fix on teh T-con board
            by silikon77
            Hi!
            Got an 70 inch Philips tv model 70pus7855/12 from scraps and I decidet to give it a go. I'm an enthusiast but no porfessional in the electronics.
            Found some advices watching youtube nad came up with this:
            It came with no picture, after diagnosing it I found out that the right side of the T.con board was faulty.
            I taped down the clock signals and I got a picture but the left side of the panel has less pronounced colours. Only the right 3rd side of the panel has good colors.
            See attached picture.
            I tried a few combinations to block individual clock...
            01-02-2025, 02:26 PM
