I have no clue what the problem is with this plasma? can anybody throw out some ideas? It says on but just the picture is screwed up im thinkn ysus?
lg plasma 42pc3d issue?
Tags: None
Re: lg plasma 42pc3d issue?
Z-sustain... read the diagnosis thread on plasmas linked in the FAQ... purple picture is almost always Z-sustian.
It will be IPMs on the Zsus in 99% of cases, rarely economical to fix for these 8-9 year old sets.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
Tom66 is correct Zsus faulty Lower IPM (common fault)
put you hand on both IPM heatsinks ,i suspect the lower will be coldComment
by lp20thI have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
by CooperrI picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board... -
by celiabrownHello guys,
My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
Can someone has any symptom like this ?
Thanks05-09-2024, 10:56 PM -
by rouninHi everyone,
🛠 Original Issue
⚠️ New Problem: One USB-C Port Only Works in One Orientation... -
by ugamazingI have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre... - Loading...
