Sony KDL-32L504 T-Con?
  • SgtRock
    • Feb 2012
    • 175
    Greetings Badcappers:
    --I am trying to fix another Sony KDL-32l504, see picture. The picture part of the signal rolls while the notification parts are steady. The red line comes and goes as the picture rolls. The gray horizontal part above which indicates the channel is fine and is not affected. This leads me to believe it might not be the tab bonds or panel. The part at the bottom which says "no signal" is transparent to the rolling picture, but it is otherwise steady. Some of the ghost pictures show a left right mirror reversal, see picture. Any advice would be appreciated.
  • SgtRock
    • Feb 2012
    • 175
    Re: Sony KDL-32L504 T-Con?
    I just downloaded the service manual for this TV. Tom: let me know if you want a copy for your archive. Oh, and tell me where to send it to, as well.
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Please share the service manual........I think it could be a Tab Bond issue as you suspect. However, I will not rule out a bad T-CON board.
      • mattstolte
        • Dec 2013
        • 612
        • usa
        i have had like 3 of these 32 inch sonys, with rolling picture it is bad panel not tcon
        • SgtRock
          • Feb 2012
          • 175
          I believe you. I have two of these in perfect condition except the screen. I checked eBay and none of the 32L504 parts seem to be moving. Oh well! The inverter board is 18" long, so no Priority Mail flat fee boxes. I will put everything that will fit into one box and offer it on eBay. I also will try selling the stand at a cut throat price. Here is the link to the service manual. http://www.electronica-pt.com/esquem...ch-ex2k-24535/ Thanks to all.
          • iglitare
            by iglitare
            09-04-2025, 07:13 AM
          • Daren87
            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
            by Daren87
            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
            08-13-2023, 03:25 PM
          • CyberPhoenix
            Issue with picture quality of Sony bravia TV
            by CyberPhoenix
            Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
            01-22-2024, 02:08 AM
          • Fly_Among_Stars
            VIZIO E70-E3 Half picture with half TCON
            by Fly_Among_Stars
            I have a VIZIO E70-E3.
            Symptoms: Black screen, no picture, but LED backlights are working.
            I probed the power board and voltages are as listed on the board.
            Main board appears fine, too.
            I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
            There are two separate ribbon cables feeding the LCD.
            If both are connected, the screen is black.
            If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
            04-24-2023, 08:20 PM
          • noisykid
            Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
            by noisykid
            5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
            12-30-2024, 07:15 PM
