Seiki 50 inch has no back light
  • bluedawg
    Bluedawg
    • Mar 2015
    • 60
    • united states
    HELLO EVERYONE I HAVE A SIMPLE QUESTION I AM GOING TO POST A PICTURE
    AND ASK THAT IF SOMEONE CAN TELL ME IF THIS POWERBOARD IS ALSO THE INVERTER FOR BACK LIGHTS. I HAVE A SEIKI SE50FY10 THAT EVERY THING IS WORKING BUT NO BACK LIGHTS AND IF THE SMALL 4 CONNECTORS ARE GOINGTO BACK LIGHT INSIDE TV , THEY HAVE NO POWER ON THEM WHEN SET IS TURNED ON. THE PICTURE IS ON SCREEN THAT YOU CAN SEE WITH FLASHLIGHT TEST AND I HAVE SOUND. I CAN NOT FIND A INVERTER ON THIS TV ANYWHERE ELSE. ALSO IF THERE IS A WAY TO CHECK A COMPONENT ON THE POWER BOARD THAT TURNS ON THE BACKLIGHTS PLEASED PROVIDE ME WITH SOME GUIDANCE. THANK YOU IN ADVANCE
  • CapLeaker
    Leaking Member
    • 8322
    Re: Seiki 50 inch has no back light
    What is the model number of your TV?
    • bluedawg
      Bluedawg
      • Mar 2015
      • 60
      • united states
      Se50fy10 model
      • jetadm123
        • 2169
        Your model is LED and does not use an inverter.
        • Terryfictv
          • Mar 2011
          • 124
          I am working on the exact same model. I have the power board ordered and when I get it next week I will help you. My symptom is click then blinking LED, subbed main board = no change.
          • bluedawg
            Bluedawg
            • Mar 2015
            • 60
            • united states
            Jetadm123 Do u have any idea what turns on lights then and where I can test to see if there is power. Or does the power board turn on back lights?
              The BL-ON signal is generated by the main board. There are no labels for the connectors pins at all so it will be very difficult to find the function of each pin. Look at the main board to see if there are labels for the connectors.
              Can I see the good straight shot of the bottom side of the board?
              • bluedawg
                Bluedawg
                • Mar 2015
                • 60
                • united states
                Budm, thank you for the response since i last posted I took the power board out and flipped it over and found all the pins to be labeled . I also found the pins where power leaves power board to go to led lights. But I accidently shorted out a resisistor and cracked it and it burnt one of the tiny tiny black little rectangle things directly underneath the resistor. Can u tell me the name of the tiny black rectangle things normally on the bottom of boards and the markings beside them normally start with a R? So now its gona take me tommorrow to figure out if i should just buy a power board for $50 and hope that would solve the original problem and the one I created? Any suggestions is greatly appreciated lesson learned on testing transistors in a tight spot
                  'R' = Resistor, but cannot tell more until we see the pictures.
                  • tw2005
                    • Oct 2011
                    • 6458
                    you might as well upload the other shopjimmy image of the underside but images of your board would be handy for BUDM. Save the SJ image, open in paint and edit to mark the spot of the "thing"
                    The other problem now is , was it the PSu faulty or PSU good and LED strips faulty.
                    Found this
                    https://www.badcaps.net/forum/showth...light=ELEFW502
                      There was no follow-up on that thread either so I did not get very far on that one.
                        • tw2005
                          • Oct 2011
                          • 6458
                          I think the server just freaked out and gave you a double post LOL.
                          True but johnboy @ post #5 mentioned his tv had bad LED strip. Since he said he had the same symptom as OP of blue light no pic,no sound assuming neither shone light to see if an image was present I can see this ending up with a replacement PSU and same fault. Just a gut feeling though.
                          I'm expecting same internals just a badge job
                            Sure did.
                            I will not be surprised that he will have bad LEDs.
                            • bluedawg
                              Bluedawg
                              • Mar 2015
                              • 60
                              • united states
                              I promise to get u guys a good picture of bottom of PSu , please understand I am still learning the Abbreviation so I am assuming PSU would be Power SUpply Unit. I do know more after studying board than I did before I shorted part of it out. At connection 1 for led strip I had power i think 260v on one pin but when I tested the other 4 cnnectors beside itI didnot have any voltage. This was true before I shorted out resistor that cracked and burnt little resistor underneath it. I will get the requested info and post it later today. Thank you all again .
                              • bluedawg
                                Bluedawg
                                • Mar 2015
                                • 60
                                • united states
                                ok heres the the exact board that I have and the red box shows the resistor on top that is blackened and cracked. The yellow box shows the resistor I have no idea if its bad or how to identify it for replacement . it did make a black mark on area underneath the board .the resistor on top is brown then black then silver then gold band . I also can not find this resistor to replace it online, i dont know the watts i know the ohms is 0.1.
                                  You need to check the resistance between the Source and Drain pin of the PFC Power MOSFET Q2 to see if is shorted out (very low Ohm), that Source resistor (0.10 Ohm) that went out for a reason, I have no idea why they put a small SMD resistor in parallel with the Source resistor, no need for that at all.
                                  • bluedawg
                                    Bluedawg
                                    • Mar 2015
                                    • 60
                                    • united states
                                    I got a new powerboard and put it in. I have 4 volts dc going to BL on power board from motherboard. When i test led connector 1 red wire it has 270 volts and the white wire has 170 . Then on led connector 2 the red has 88 volts and 0 on white then connector 3,4,5 all have 0 on both red and white wire. Obviously im lost here on why the backlights will not come on . Is there any way to put power to leds just to see if they will come on . I can not find a inverter or a led driver. Thank u advance im really baffeled.
                                    • bluedawg
                                      Bluedawg
                                      • Mar 2015
                                      • 60
                                      • united states
                                      I got a new powerboard and put it in. I have 4 volts dc going to BL on power board from motherboard. When i test led connector 1 red wire it has 270 volts and the white wire has 170 . Then on led connector 2 the red has 88 volts and 0 on white then connector 3,4,5 all have 0 on both red and white wire. Obviously im lost here on why the backlights will not come on . Is there any way to put power to leds just to see if they will come on . I can not find a inverter or a led driver. Thank you in advance im really baffeled.
                                      • bluedawg
                                        Bluedawg
                                        • Mar 2015
                                        • 60
                                        • united states
                                        Mr Budm Now that I replaced power board I can tell you I have 5volts dc going to BL pin on powerboard and I have power on red and white wire connector 1 for back lights and power on red only wire on conector 2 for BL and no power on other 3 connectors . I think it was like 240 on 1st connector red wire and 120 on white wire 1st connector and 88 on red wire on 2nd connector. Hope this helps you help me.
                                          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                          by sam_sam_sam
                                          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                          I am comparing them to a brand new one that I installed
                                          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                          I going to let it run for several days before I remount back on the wall next to the...
                                          09-05-2024, 06:48 PM
                                        • PNI E.
                                          tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
                                          by PNI E.
                                          hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
                                          02-20-2025, 08:36 AM
                                        • koby058
                                          vostro comes up with back light but no picture
                                          by koby058
                                          Hi people!!
                                          The owner said it showed bad picture once in a while (attached)
                                          I see that there is back light but no picture.
                                          I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
                                          Also attached schematic and BDV
                                          LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
                                          07-13-2025, 01:03 PM
                                          HP ZBook Firefly 16 inch G10 Notebook Specification for Upgrade or Repair
                                          This specification for the HP ZBook Firefly 16 inch G10 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 inch G10 boardview and 16 inch G10 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-07-2024, 07:20 AM
                                          09-07-2024, 07:19 AM
