Samsung pn60e530a3f sound no picture
  • johns1mj
    • May 2015
    • 242
    I followed a similar thread from back in January and did not get any results.
    I bought a 60" plasma that would intermittently display the picture. It would always have sound. After a couple days it would no longer display at all. The logic board will flash every 5 seconds. I found two televisions with the same boards. I bought both television sets with cracked screens (cheap). I changed all the boards. Still no picture. Same result with the logic board. I changed the y main and buffers, x main and buffer, the power board and all the cables. from the 3rd set. Still no change. The ve and va voltages are good. If i unhook the ribbon to the y main the logic board flashes normally. Any advice on what next?
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Samsung pn60e530a3f sound no picture
    Whats the Vs, VScan and -Vy voltages doing?
    TELEFIX
    • johns1mj
      • May 2015
      • 242
      Va and VA are normal 211 and 57
      • Hamie
        • Apr 2014
        • 1383
        Yeah but what's the vscan?
        Test point located on the ysus.
        Have you tried test patterns?
        • johns1mj
          • May 2015
          • 242
          vsc and -vy test point I could not find. I tested at the connector but got a really low number and figured I was doing it wrong. The only way I got vs and va numbers was with the ribbon between the logic and y-main disconnected. If connected the tv goes into protect mode.
          • johns1mj
            • May 2015
            • 242
            I would feel better about shorting out pins if I had a picture of what pins. I see lots of people talk about doing it but couldn't find a picture.
            • Hamie
              • Apr 2014
              • 1383
              Ok upload a picture of your ysus and a picture of the control board (the one with the flashing green light)
              • Hamie
                • Apr 2014
                • 1383
                Think I've located your ysus.
                Here is the vscan test point.
                • Hamie
                  • Apr 2014
                  • 1383
                  For test patters connect holes 3 and 4 with a bit of wire, located here:
                  • newtothis
                    • Mar 2013
                    • 1556
                    • england
                    Need to remove LVDS cable too
                    • johns1mj
                      • May 2015
                      • 242
                      Found the vscan and the ve points voltage on power up is correct -198 and 98 on start up. After 5 second the voltages begin to drop.
                      Newtothis said I need to remove the lvds cable. Which one I have 5 ribbons. Two go to the lower boards. One to the y-main, x-main and one to the video input board. I assume it is the video input cable he referred to.
                      • newtothis
                        • Mar 2013
                        • 1556
                        • england
                        Yes to your assumption
                        • johns1mj
                          • May 2015
                          • 242
                          No display pattern, no flash of screen.
                          • newtothis
                            • Mar 2013
                            • 1556
                            • england
                            Ok rules out mainboard, Unfortunately that's as much as I can help regarding Plasma
                            • johns1mj
                              • May 2015
                              • 242
                              Thank you for trying.
                              • Hamie
                                • Apr 2014
                                • 1383
                                You positive the panel isn't cracked?
                                Get a torch and shine it into the corners, even the smallest crack will result in this fault.
                                  There's a pretty common fault on these caused by a bad SMPS controller IC on the Y-main, but it usually causes Vsc to stay low. Thread here, if you wanna try a quick check or two:
                                  https://www.badcaps.net/forum/showthread.php?t=43075
                                  • johns1mj
                                    • May 2015
                                    • 242
                                    Well anything could happen. The tv would turn on every other time when I started this. I have not been able to see a crack yet.
                                    Thanks tom66 I did read through that one.
                                    • johns1mj
                                      • May 2015
                                      • 242
                                      Looks like multiple bad boards. ok up date. Bad y buffer board. I changed two capacitors for looks. They tested fine off the tv. All voltages were good. I swapped y buffer for fun and it fires right up.
                                      • drussell
                                        • Nov 2014
                                        • 144
                                        All va, vs,vscan and ve all checked good on startup. Just for fun I swapped y buffer boards. tv fired right up. So I have 2 bad y mains and at least one bad buffer.
                                        You should always be testing the Y-buffers boards for shorts before trying to power one up, especially if they came from a cracked-screen set since that is the most likely part to blow. (Not that they will always show a short if they are bad but it is a definite bad sign if anything is shorted.) You're lucky you didn't blow a good Y-Main board with a bad buffer board.
                                        The Y-Mains are often easy to fix. Check the non-working Y-Mains for shorts in the power devices and if there don't seem to be any, verify that they do not have the -Vscan problem. Those seem to be by far the most common faults on these sets.
                                        It is much easier with a working TV to test and repair anything that is an easy fix so you have spares.
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
                                        • Dodgethis
                                          Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                          by Dodgethis
                                          Hello all,
                                          This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                          09-11-2024, 07:39 AM
