Samsung LN40D630 Vertical Lines
  • Gj1121
    • May 2015
    • 5
    I have been trying to figure out the source of vertical lines on Samsung LN40D630M3FXZA. The vertical lines do not effect the bottom 2-3 inches. No distortion in that area. The lines are over the menu and as the unit is on will migrate some, but that seems to be dependent on the intensity of the image on the screen. I have noticed that when I turn down the contrast to 50 the vertical lines will disappear once I exit the menu. Bright white images in menus will cause the vertical lines to reappear above and below the white image. Also shows up on bright app screen of apple tv. But playing movie with contract down it is almost normal. Has some thin lines in image except bottom 2-3 inches.
    Replaced t-con board. No change. Not sure if bad panel or main board. The only other person I found on line with problem said it was bad panel. But one person told him it was bad soilder on main board.
    Any help narrowing down problem would be appreciated.
  • Hamie
    • Apr 2014
    • 1383
    Re: Samsung LN40D630 Vertical Lines
    Bad panel by the looks of it.
      Agreed, another dead Samsung LCD panel. I have an LE40A656 at home which does this, turning down contrast helps.
      • newtothis
        • Mar 2013
        • 1556
        • england
        +1
        Bad Panel
        • Gj1121
          • May 2015
          • 5
          Thanks for the input.
          • Falki
            Colorful LCD Vertical Lines on Samsung ue55es8090
            by Falki
            Hello there, ive recently found an older 55inch Samsung SmartTV.
            A similar issue has been posted as well but also with no actual response ...
            08-12-2025, 04:19 AM
          • Stanley1843
            by Stanley1843
            06-29-2024, 11:54 AM
          • pni
            LG 49uf695v vertical coloured lines
            by pni
            Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
            11-14-2025, 03:15 AM
          • x_orange90_x
            Samsung UN46C8000XFXZA vertical bars/horizontal lines
            by x_orange90_x
            I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
            The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
            09-04-2023, 12:09 PM
          • polaro
            Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
            by polaro
            Greetings,
            I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
            08-27-2022, 08:46 AM
