toshiba 32av555d wont turn on
  • cvel
    • May 2015
    • 64
    • United Kingdom
    Re: toshiba 32av555d wont turn on
    Unplugged board with HDMI ports on and TV stays in standby mode no clicking just solid red standby light
    • cvel
      • May 2015
      • 64
      • United Kingdom
      Unplugged board with HDMI ports on and TV stays in standby mode no clicking this time just solid red standby light
      • Hamie
        • Apr 2014
        • 1383
        You can't unplug that board as the TV won't turn on as the power supply gets the ps-on signal from the mainboard.
        I'm talking about unplugging the inverter board. I believe it must be hidden underneath the mainboard.
        • cvel
          • May 2015
          • 64
          • United Kingdom
          Yes I unplugged that first and TV still does same thing
          • Hamie
            • Apr 2014
            • 1383
            Ok well there's not much more you can do untill we get some voltages.
            It might be worth heating up the mainboard and seeing if it comes back to life.
            But if that doesn't work you'll need to wait until you get your meter.
            • cvel
              • May 2015
              • 64
              • United Kingdom
              #26
              OK thank you its getting a little late now so will try heating main board tomorrow if doesn't work I will wait for the multimeter to be delivered and get back to you thank you for your help so far its very much appreciated.
              • cvel
                • May 2015
                • 64
                • United Kingdom
                #27
                Good afternoon, I have tried heating the main board and nothing happened to I changed all the caps that can today from Amazon and still no change multimeter should be here Tuesday or Wednesday
                • cvel
                  • May 2015
                  • 64
                  • United Kingdom
                  #28
                  Hi sorry it's been a while I now have a multimeter to hand if you could help me with trying to find this fault I would be very great full thank you
                  • ChristianBr01
                    LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                    by ChristianBr01
                    I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                    The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                    What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                    04-23-2025, 01:48 AM
                    09-06-2024, 05:27 AM
                  • Jackching
                    Samsung UN46EH5000F wont turn on. Blinks red standby light continuously
                    by Jackching
                    I know for sure it has a bad cap and one cold solder joint. Just wondering before i order the Caps if anyone has any experience with this model? Just making sure there isnt a common component that goes bad besides the caps....
                    04-15-2024, 05:14 PM
                  • PNI E.
                    Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                    by PNI E.
                    Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                    03-17-2025, 04:23 AM
                  • brithepi2k
                    Sony KD-65XE8596 no standby light
                    by brithepi2k
                    I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
                    cheers...
                    09-06-2025, 02:22 PM
